rough idle
i have a 92 integra stock motor with just cold air intake.
here goes the problem:
-when i start my car (cold) my idle would stay at 2.8k rpm then goes up to 3rpm and by the time it hits 3rpm it would jump from 1.8 to almost 3 rpm but when its warm it would usually be around 1.4-1.8 rpm(not normal).
-i clean aicv and saw that it was really dirty black so i cleaned it and put it back so its still doing the same.
****so please anyone tell me what is wrong with my car or give me an idea on how to fix this cause this is really getting annoying...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imroadk1ll »</TD></TR><TR><TD CLASS="quote">could b ur motor mounts</TD></TR></TABLE>
LOL? Okay like motor mounts will cause idle surge.
Most likely you have a vacuum leak. Does it do the same when the engine is warm? When I tried to set the idle on the car it did the same thing when I disconnected plug and forgot to plug it back in. Try resetting the battery and make sure everything is plugged in (hoses, plugs, etc)
IT WILL DO YOU NO GOOD TO CLEAN THE IACV if you dont clean the FITV read the article in the FAQ its under the the throttlebody and it has a piece that needs to be tightened after u reomve 2 screws and the cover.
other wise its a vacuum leak.
sleepyhamsterlx
Dec 4, 2003 07:35 PM
