Wheel Back into the wheel-well
My front right wheel is set back about an inch into the wheel well. It is straight back and i have no what part is causing it. My sister did curb it and there is no doubt that it is the cause, if anyone else has experienced this, please tell me what part might be broken/bent. Thank you.
Re: Wheel Back into the wheel-well (Tarlacon)
check your lower control arm. last time i hit a curb HARD and it was the lower control arm. might wanna check the toe adjuster thingy too. you might be able to get away with an alignment, but if you cant, most likely they'll tell you what is fucked up
Re: Wheel Back into the wheel-well (Advan06)
i hit a curb due to wet leaves on a u-turn/ jughandle and it threw the control arm straight back into the damn wheel well. Honda will catch you about 250 for a new one, i guarentee its the control arm
Homesickelian
03-05-2007 04:06 AM
