rich or lean?
Old Apr 22, 2007 | 01:59 PM
thizboii's Avatar
Default rich or lean?
Ok guys, i got a little problem here. My autometer air fuel ratio guage indicates that my car is running very lean and it bogs at idle and also around 2500 rpms. But when i took my plugs out to see, they were black as if it was running rich? fuel filter gauge is at 46psi, and also for temp i'm running a p28 ecu on a b20b motor. could that be the problem? Thanks for the help guys!
Old Apr 22, 2007 | 04:25 PM
thizboii's Avatar
Default Re: rich or lean? (thizboii)
bump
Old Apr 22, 2007 | 04:45 PM
Opo's Avatar
Opo
I recently had a running rich problem. As you just said i pulled my plugs and they were black as hell so i cleaned them and checked them in a week just to confirm and yeah they were black again so i did some research and found out my AEM FPR was set 8 PSI to high for my engine. So I made the adjustments and the mileage has been so kick *** ever since lol.
92 GS with 2nd gen B16A engine swap in it, set to 36 PSI with the vacuum hose OFF the FPR. just to give you an idea.
it definitely sounds like ur running rich to me and that you need to adjust ur FPR badly.
Old Apr 22, 2007 | 06:10 PM
thizboii's Avatar
Default Re: (Opo)
well, the thing is that i'm running a stock b20 fuel rail, b20 fpr, dx injectors and a walbro 255... Could it be that the fpr is bad? running too rich would cause it to bog like it is? Thanks for the help.
Old Apr 23, 2007 | 04:20 AM
D16Cowboy's Avatar
Many conditions could cause blackness of the plugs, including oil fouling.
Old Apr 23, 2007 | 05:44 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: (thizboii)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thizboii &raquo;</TD></TR><TR><TD CLASS="quote">well, the thing is that i'm running a stock b20 fuel rail, b20 fpr, dx injectors and a walbro 255... Could it be that the fpr is bad? running too rich would cause it to bog like it is? Thanks for the help. </TD></TR></TABLE>
That pump probably bumped up your pressure to what it is,
do you have an adjustable FPR? If you do, set it back down to 38-40 psi.
And that a/f ratio gauge you have, if it's the one you can get for $50-70(narrow band),
you won't get **** from that, all it does it blink lights, don't use it as a guide.
Old Apr 23, 2007 | 06:38 AM
thizboii's Avatar
Default Re: (CleanLikeJdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanLikeJdm &raquo;</TD></TR><TR><TD CLASS="quote">That pump probably bumped up your pressure to what it is,
you won't get **** from that, all it does it blink lights, don't use it as a guide.</TD></TR></TABLE>
No, i don't have a adjustable fpr but i'll probaly pick one up now to see what happens... Yeah it's the narrow band air fuel gauge... As for the oil fouling, it's pretty much dark already, less then a mile on it too. anyone else got any ideas? Thanks for the help guys.
Old Apr 23, 2007 | 08:51 AM
suspendedHatch's Avatar
Actually a narrow band O2 sensor is perfectly fine for telling you if you're running rich or lean. It just wont tell you HOW rich or lean and you can't tune with it.
P28 on a B20... You need to either run the correct ECU for the motor or get a standalone like the AEM EMS and get it tuned. Nothing else in the world will compensate for the wrong ECU, and you will never experience the potential of the motor. You may even destroy it.
Old Apr 23, 2007 | 01:43 PM
Richard...'s Avatar
Default Re: (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">Actually a narrow band O2 sensor is perfectly fine for telling you if you're running rich or lean. It just wont tell you HOW rich or lean and you can't tune with it.
P28 on a B20... You need to either run the correct ECU for the motor or get a standalone like the AEM EMS and get it tuned. Nothing else in the world will compensate for the wrong ECU, and you will never experience the potential of the motor. You may even destroy it.</TD></TR></TABLE>
p28 chipped will take care of all your problems with a good tune of cause and no need for a fpr if you have it chipped and tuned
Old Apr 24, 2007 | 04:03 PM
thizboii's Avatar
Default Re: (richard7968)
thanks for the help guys... Would a bad oxygen sensor cause it to run rich as it is?
Old Apr 24, 2007 | 04:56 PM
Richard...'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thizboii &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the help guys... Would a bad oxygen sensor cause it to run rich as it is?</TD></TR></TABLE>
check for the code could be???
Old Apr 25, 2007 | 06:42 AM
thizboii's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by richard7968 &raquo;</TD></TR><TR><TD CLASS="quote">check for the code could be???</TD></TR></TABLE>
another then the vtec codes 21,22, There nothing else. Anyways i changed the oxygen sensor and also found a slight fuel leak on one of the injectors... AND idle is now perfect... Thanks alot guys for the help!!!
Old Apr 25, 2007 | 02:40 PM
Richard...'s Avatar
another then the vtec codes 21,22, There nothing else. Anyways i changed the oxygen sensor and also found a slight fuel leak on one of the injectors... AND idle is now perfect... Thanks alot guys for the help!!! </TD></TR></TABLE>
Good to hear another problem bites the dust!
DawgC2
Mar 10, 2012 12:11 PM
w0ng_sta
Sep 8, 2006 06:54 PM
honda9369
Sep 21, 2004 11:40 PM
JDM KING
14
Sep 20, 2004 10:59 PM
Burke
Jul 24, 2003 01:14 PM
