RHD conversion on integra
Old Mar 19, 2007 | 07:24 AM
brian L.'s Avatar
Default RHD conversion on integra
Hi just just wanted to know if i had everything for my 93 integraDA.How hard/ez would it be to make it right hand drive what would i need and any other tips would be helpful.thanks
Old Mar 19, 2007 | 07:33 AM
94rs-turbo's Avatar
save yourself time and effort do worry about doing rhd
Old Mar 19, 2007 | 07:57 AM
brian L.'s Avatar
Default Re: (94rs-turbo)
I'm still gana do it.I just want to know from people who have done it befor
Old Mar 19, 2007 | 09:06 AM
brian L.'s Avatar
Default Re: (DA69OG)
bump
Old Mar 19, 2007 | 11:00 AM
rhda6's Avatar
da and ef are realy hard to do it. no room to cut nor weld but possible. do you have any body work or any type of experience like that? and are you machnically inclinde. (do you do your own work)? if not don't do it.
Old Mar 19, 2007 | 11:05 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Unless you're very skilled in welding, and what would expletive the frame up,
then you might wanna read up, or do something a bit more before this.
I doubt a shop for cut out your firewall, and put a different one in that probably isn't even legal for them to do.
Swapping pretty much your Whole front end, isn't like changing your rims.
Old Mar 19, 2007 | 11:29 AM
53JDMDC2's Avatar
Default Re: RHD conversion on integra (DA69OG)
you are going to have to cut the fire wall off to do it right. you also need a frame alignment table.
not worth the work. it cheeper to by a whole DA that is already RHD
Old Mar 19, 2007 | 11:41 AM
bigluelok's Avatar
my homie just did a fire wall swap and just swapped everything from his firewall to the new firewall
Clipsed
Oct 9, 2012 10:11 PM
btlfed1
Jun 12, 2003 09:04 PM
88civicHB703
12
Apr 19, 2003 10:45 PM
LouisM
Mar 9, 2003 03:09 PM
MaD3 In JaPaN
Apr 23, 2002 08:15 PM
