reverse indiglos
Old Jul 9, 2003 | 10:27 PM
sonicblueteg2k's Avatar
Default reverse indiglos
i have reverse indiglos and was driving and all of a sudden they just died. I was thinking that it could have been a fuse but the lights behind it work, does anyone know what the problem could be
Old Jul 9, 2003 | 11:50 PM
sPaRk'iT's Avatar
Default Re: reverse indiglos (sonicblueteg2k)
uummm....your ground probably got lose, it happens to mine b4. check your gound and postive wires.
Old Jul 10, 2003 | 12:37 AM
Default Re: reverse indiglos (sPaRk'iT)
k thanks
Old Jul 10, 2003 | 02:23 AM
nek0's Avatar
How long did you have these? Those after market indiglo's are VERY cheaply made & it won't last very long, few months if you're lucky. Mine died in about two months...still sitting there as a white gauge A lot of the shops pulled them off for the same reason.
Old Jul 10, 2003 | 02:31 AM
NightRiderS2K's Avatar
In-N-Out Burger
Default Re: reverse indiglos (nek0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nek0 &raquo;</TD></TR><TR><TD CLASS="quote">How long did you have these? Those after market indiglo's are VERY cheaply made & it won't last very long, few months if you're lucky. Mine died in about two months...still sitting there as a white gauge A lot of the shops pulled them off for the same reason.</TD></TR></TABLE>
I disagree. The ones that don't last are the el-cheapo ones off ebay that run from $5-$20.... do you 'concur'?
sonicblueteg2k: it has nothing to do with the fuse,..as mentioned, its usually the ground connection. why dont you check out all the connections? negative/positive and from the main relay to the gauges. check if anything is fried.
good luck!
cheers
NRG
Old Jul 10, 2003 | 10:18 AM
i didnt put them in so im not sure how to check, they glued the reverse indiglos to the stock gauges so does this mean i might need new stock gauges
Old Jul 11, 2003 | 01:58 AM
In-N-Out Burger
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sonicblueteg2k &raquo;</TD></TR><TR><TD CLASS="quote">i didnt put them in so im not sure how to check, they glued the reverse indiglos to the stock gauges so does this mean i might need new stock gauges</TD></TR></TABLE>
If you are not a membet of Team-Integra.net, sign up now, because many knowledgeable members have contributed countless articles that I use to redirect people hungry of information...
One note...please do not panick and worry about new gauges. I do not know how experienced you are with D_o I_t Y_ourself projects or hands on, self -installations. If you are inexperienced, a little trial and error will not hurt you. Trust me on this one. Ready? Point your browser to:
http://www.team-integra.net/se...ID=84
Good luck and if you have further questions, I will be of great assistance.
CHEERS
NRG
Old Jul 11, 2003 | 02:04 AM
xteg95's Avatar
Default Re: reverse indiglos (NightRider-gsR)
yea check the connection first, i had a pair a couple years ago that only lasted like 5 months...might have just gone bad.
Old Jul 11, 2003 | 03:51 AM
TegLove's Avatar
I had reverse indiglos in my civic for a couple years.....i agree that its the cheapo's from ebay that suck!
Old Jul 11, 2003 | 06:54 AM
MikeTV
Guest
Posts: n/a
Default Re: reverse indiglos (TegLove)
Do not believe the hype that indiglo gauges only last a couple of months. The problem is that alot of people hook up the light source to their dimmer switch, and the instruction clearly state not to do that. They also say that if you do hook them up to the dimmer switch, it will eventually short the gauges out. I hooked mine up properly in my previous teg about a year and a half ago, and they still work problem free today.
Old Jul 14, 2003 | 03:25 PM
In-N-Out Burger
Default Re: reverse indiglos (Eclipse spanker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eclipse spanker &raquo;</TD></TR><TR><TD CLASS="quote">Do not believe the hype that indiglo gauges only last a couple of months. The problem is that alot of people hook up the light source to their dimmer switch, and the instruction clearly state not to do that. They also say that if you do hook them up to the dimmer switch, it will eventually short the gauges out. I hooked mine up properly in my previous teg about a year and a half ago, and they still work problem free today.</TD></TR></TABLE>
I disagree on this one... I have hand-me down used Indiglo gauges from my cousin and I hooked it to my dimmer switch. Its been on for more than 6 months... *knocks on wood*
I cannot stress this further:
CHEERS
NRG
Old Jul 14, 2003 | 04:48 PM
ernald711's Avatar
i got mine about 3 years ago and they still work. don't kno what brand they are anymore but it came with an aftermarket dimmer switch that i juss let hang into the coin holder thing. one thing that went wrong was that one of the wires to the dimmer go disconnected so it used to go on and off whenever it felt like it.. i juss soldered the wires and now they work good.
Old Jul 14, 2003 | 06:13 PM
LillDragun's Avatar
Default Re: reverse indiglos (ernald711)
if you want some new ones i have some that are brand new that i bought and don't want for a non vtec integra.
Old Jul 14, 2003 | 06:16 PM
Loveless's Avatar
Default Re: reverse indiglos (LillDragun)
I concur. Usually there are more than 1 relay for indiglo, if all three face died then it's power, check postive or ground. If at least one face is up then it's one of the relay
Old Jul 15, 2003 | 01:37 PM
In-N-Out Burger
Default Re: reverse indiglos (Loveless)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loveless &raquo;</TD></TR><TR><TD CLASS="quote">I concur. Usually there are more than 1 relay for indiglo, if all three face died then it's power, check postive or ground. If at least one face is up then it's one of the relay</TD></TR></TABLE>
GJ loveless... BTW: you can add me to your vouch list . I'm still trying to fix the light output of that one xenon bulb...sucks huh?
CHEERS
NRG
l2yanE
Jul 31, 2005 10:03 PM
Mackenzie
Dec 23, 2004 04:39 PM
Alberto
Sep 23, 2004 02:55 PM
cheyennerex
May 25, 2003 08:00 AM
