rev problem?
Old Jun 5, 2006 | 11:14 AM
94whitegsi's Avatar
Default rev problem?
i got a 97 gsr and all da time i turn it on it revs up to 2000rpm or 1500rpm and it doesnt go down...i got a obd1 p72 on it wat do you think it is????
Old Jun 5, 2006 | 12:36 PM
Circuit Star-29's Avatar
Default Re: rev problem? (97redtegra)
Vac leak or bad ECU...could also be the dizzy...
Old Jun 5, 2006 | 01:11 PM
94whitegsi's Avatar
Default Re: rev problem? (Circuit Star-29)
it dont gave vac leak because if you take one off it rev even more
Old Jun 5, 2006 | 01:30 PM
virus916's Avatar
reset ecu properly when engine is cool.
Old Jun 5, 2006 | 01:33 PM
Default Re: rev problem? (virus916)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97redtegra &raquo;</TD></TR><TR><TD CLASS="quote">it dont gave vac leak because if you take one off it rev even more</TD></TR></TABLE>
Dood...a pin hole will cause a surging idle...
Only one way to reset an ecu...this will only be a very shortterm solution...
Old Jun 5, 2006 | 02:45 PM
qfast817's Avatar
see if your throttle cable is sticking or to tight
Old Jun 5, 2006 | 03:16 PM
virus916's Avatar
Default Re: rev problem? (qfast817)
well, slap on your stock ecu and see if the problem still persists. If your prob goes away then its the obd1 ecu thats causing your prob.
Old Jun 5, 2006 | 03:18 PM
trick_db's Avatar
check your throttle body.. that ball joint mite be lose to tyte it up, it happen to my friend couple year back, but then he got it fix, and thats the reason why..
kwell
Oct 31, 2011 04:16 AM
coupe_hybrid
14
Aug 15, 2005 09:46 PM
Junkyard2000
Aug 13, 2005 11:07 AM
trooper0641
21
May 19, 2004 08:49 AM
WAFFLES
Apr 25, 2003 01:42 PM
