reusing the block?
Old Jun 30, 2006 | 04:49 PM
acman1's Avatar
Default reusing the block?
noobish question, if you have spun a bearing, is the block usually still useable? what parts are normally damaged if this happens? i realize it could be anything, but i have no way to get into it myself and figure out what is f'ed and what is reusable. thanks.
greg
Old Jun 30, 2006 | 08:47 PM
-Darren-'s Avatar
Default Re: reusing the block? (acman1)
i know the crank is usually damaged and needs to be replaced or sent to a shop.
Old Jun 30, 2006 | 11:02 PM
DC2 Mang's Avatar
blocks are re-usable with spun bearings, the only time you cant is if the rod bolts snap and the rod start bashing around inside
get a new crank and get in balanced with new bearings and a new rod if necessary and make sure all clearances are within spec. put some new rings in and you will be good to go
SuckMyDOHC
Jun 15, 2008 11:29 AM
RyanA
Jul 17, 2007 04:14 PM
(puma)
Oct 12, 2005 02:48 PM
PrecisionH23a
Jul 30, 2002 02:28 AM
canuck-mx6
Jun 3, 2002 04:38 PM
