retorque problems..... help pls
Old Sep 21, 2008 | 10:56 AM
ishnathan's Avatar
Default retorque problems..... help pls
my car keeps leaking oil where my bottom block meets the head so basically right in the middle where the head gasket sits i resurfaced the head used new headgaskets each time and im using arp head studs also the torue setting for the headstuds im using is the stock torque for the integra
i did this 3 times already and now im running out of ideas should i just get rid of the bottom block or just retorque the headstuds with more pressure oh and before i forget the bottom block and head were machined before i forget to mention that so everything is straight.................PLS HELP I'M SERIOUSLY STUCK
Old Sep 21, 2008 | 11:48 AM
bakertime's Avatar
Default Re: retorque problems..... help pls (ishnathan)
Are you sure it's coming out of the headgasket, and not the cam plug, VTEC solenoid gaskets, or Distributor o-ring? I have a cam plug leak right now and it pools right where the head gasket sticks out above the engine code stamp on the block. Also, don't ARP headstuds have their own torque recommendations that are different from stock? I've never used them, but I think I recall hearing that somewhere.
Old Sep 21, 2008 | 11:55 AM
dc4-b20's Avatar
Remember that your not supposed to only torque them down to the correct spec there is also a certain order of how to torque em down. (criss cross type pattern) if you didnt do this you have a very very high chance of leaking oil/compression loss etc..
Old Sep 21, 2008 | 04:51 PM
ishnathan's Avatar
Default Re: (dc4-b20)
i did the criss cross pattern and i put it on without the v-tech solenoid and another without still leaking but ya maybe ill try to retorque with more pressure unless you have more ideas
Old Sep 21, 2008 | 06:39 PM
TOO MUCH TORQUE's Avatar
did you torque them in different specs? for example at 20 then 50 then 70?
Old Sep 21, 2008 | 06:57 PM
ishnathan's Avatar
Default Re: (ishnathan)
ya i used the three different torque specs and used the stock torque spec as the last in rotation
Old Sep 22, 2008 | 11:52 AM
bakertime's Avatar
What did you lube the studs with when you installed them? I just searched real quick and in some situations, you're going to want to torque higher with the ARP's. Here's a guy that used 30w, and ARP told him to torque to 85:
https://honda-tech.com/zerothread?id=1327031
Did you check the Cam Plug, and below the distributor to make sure those aren't leaking? I suspected a HG leak, when it was only my cam plug on mine. It seriously pools up right on the HG and looks like a leak. I would double check if you haven't already.
90ZCREX
Jun 3, 2011 10:07 PM
JDMlyfestyle
28
Jul 20, 2006 04:20 PM
ALL MOTOR DA
11
May 1, 2006 02:48 PM
LsVtakYO
10
Dec 5, 2005 10:53 AM
JDMlyfestyle
Nov 1, 2005 10:10 AM
