Replacing Thermostat
Since the search function is not working properly I am having trouble finding answers to my questions. I'm replacing a thermostat in an integra today. Can anyone please explain the install for me. Thanks. I have never done this before, but I am learning how do all this on my own, so any help would be great. Pictures help too. Thanks.
-Kev
-Kev
Clear a path to work.
Remove the ground strap and disconnect the fan thermoswitch connector.
Remove a couple of 10mm bolts and crack open the housing.
When you install the new thermostat, make sure the alignment pin faces in teh correct orientation.
http://www.bseries.net/html/garage/thermo.php
I just pop off the housing, swap the thermostats, pop it back on, bleed the lines and go to town
EDIT-where you at the ITR expo last year? I was there with a friend of mine.
[Modified by B8TeenRex, 1:49 PM 4/2/2003]
vinuneuro
Sep 10, 2013 05:56 PM
EF7
Apr 22, 2008 04:41 PM
DomDomBoy
Nov 19, 2001 07:43 AM
honda-tech. Thanks.
