replaced starter and battery still no start?!?!?!
Old Jul 7, 2005 | 04:28 PM
OPTION2ek V.2's Avatar
Default replaced starter and battery still no start?!?!?!
i have an 94 integra 5spd and recently my car wont start till i turn the key like 20-50 times.at times it will start after 1 turn.i replaced the starter and the battery and it still giving me the same problems...is there another part im suppose to replace?help honda-tech!!
Old Jul 7, 2005 | 04:30 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
check your clutch switch under the dash. mine's starting to go out and I really have to press on the pedal to get it to start sometimes.
Old Jul 7, 2005 | 04:32 PM
97tegGS's Avatar
either that or the ignition switch could be going bad. The contacts aren't making good contact.
Old Jul 7, 2005 | 04:55 PM
Default Re: replaced starter and battery still no start?!?!?! (OPTION2dcR)
is there a way i can check if they are still working?i dont want to buy both items and ends up not being both of them.. ..also thanks for the replys!
Old Jul 7, 2005 | 05:00 PM
maxxdout's Avatar
dont post up much cause im kinda out of the honda scene but ill give it a shot. This problem is very very common ammoung VW/audi/porsche. 9 times out of 10 the ignition switch is the problem, pull the covers off, and you should be able to unplug the switch from the key mechanism, try turning it with screw driver or something that way you can see it turn and see if there are problems. I don tknow about honda ignition switches but the VW part is like 24 bucks.
Good Luck
Old Jul 7, 2005 | 05:07 PM
94~GSR's Avatar
i might be wrong but from what i think it might could be your Distributor madual
Old Jul 7, 2005 | 05:35 PM
JunTec's Avatar
Default Re: replaced starter and battery still no start?!?!?! (94~GSR)
it cloud be something really simple as a ground wire...
wouldnt hurt to check your tranny ground wire...
Old Jul 7, 2005 | 05:45 PM
Absubtle's Avatar
get a test light, test the signal wire on starter when attempting to crank. If light from test light goes on then problem w/ starter still. If not, then peek your head under the dash, look for the clutch sensor plug. Unplug it, and bypass it w/ a paperclip. Try to start car. If it still doesnt work. Try checking start wire at ignition switch. I will reply back w/ proper wire color, have to look it up.
Absubtle
PA
Old Jul 7, 2005 | 05:55 PM
Default Re: (Absubtle)
cool ill try all this tomorrow..thanks again all and wish me luck
Old Jul 7, 2005 | 05:56 PM
Absubtle's Avatar
If there is no clicking sound coming from the starter solenoid, then check the Black/White wire on the Ignition Switch harness. That is the the starter input wire. Use test light and see if it lights up when you go to crank position. Let's us know what you find...
Absubtle
PA
Jmx305
12
Dec 9, 2013 03:20 AM
funkygrl
Nov 16, 2012 08:44 PM
bywaters
16
Jan 14, 2009 05:04 PM
b18bme
Mar 16, 2006 12:43 PM
buzlink
Aug 6, 2001 02:11 PM
