replace light bulb on cluster
Old May 19, 2004 | 11:20 AM
sleepyIntegra's Avatar
Default replace light bulb on cluster
Hi,
I have a 97' integra (auto). The light bulb on the "D" display is burned.
anyone knows who to replace it? what kind of bulb do I need?
thanks
Old May 19, 2004 | 02:21 PM
freakin's Avatar
Default Re: replace light bulb on cluster (sleepyIntegra)
Not sure about the 3rd gen integras, but I assume it's the same as the 2nd gens. You'll have to pull the cluster out, then the bulbs are on the back. You just twist them 45 degrees or so and the harness comes out (kinda like marker lights). Take a look at the pic. It's a G3 auto cluster that I found on ebay. The bulbs are the black circles scattered around. You can see 7 of them kind of in a vertical line down the middle (2 are blocked by the wiring in that pic). 'D' should be the one in the middle of them.
As far as what bulb to use, I can't remember that either. I just went in to my mechanic's stack of bulbs and compared my old ones to the new ones.
Hope that helps.
Old May 19, 2004 | 06:26 PM
integrx's Avatar
New User
blub to use, 194 or 168
Old May 20, 2004 | 06:11 AM
Default Re: replace light bulb on cluster (freakin)
thanks
DvrkLord
Nov 20, 2013 03:10 AM
miguey310
50
Jan 23, 2010 07:33 PM
lilvietboy
Lighting
Jul 23, 2008 03:27 PM
Midori Green
Nov 15, 2007 07:47 AM
BoostinEJ1
Jan 14, 2006 04:07 PM
