Removing mud flaps....
Old Jun 11, 2006 | 08:47 AM
Nushuktan Tulyiagby's Avatar
Default Removing mud flaps....
I took all four of the mud flaps off, but it seems like the body (rear bumper) is flimsy without them bolted on, especially in the rear. One thing i was thinking of doing would be to cut away the mud flaps that stuck out from the body and leave that part that fit the curve of the wheel wheel bolted on without any extra mud flap hanging out/down.
So its either leave them off completely or cut them down and have them be a little more aerodynamic. Suggestions? Do integras that never came with mud flaps have flimsy bumpers as well??
Old Jun 11, 2006 | 08:55 AM
revautousa's Avatar
There should be no reason for the mudflaps to make any big difference in stability of the bumper. Is the bumper mounted correctly?
Old Jun 11, 2006 | 10:15 AM
Sam92Teg's Avatar
Default Re: Removing mud flaps.... (Nateblizzy)
Did you reinstall the bolts back?
Old Jun 11, 2006 | 10:17 AM
Default Re: (DA JeLLie)
well, in the rear it connects the inner side of the wheel well to the exterior side of the wheel well (if that makes sense)...But yea, i'm pretty sure there was a plastic piece missing in the rear that goes under the mud flap that goes along the wheel well.
anyways, i just finished cutting off the excess plastic with an exacto knife and bolted the modified mud flap on. Problem solved. The front ones were just removed completely.
Now i just need a drop lol
Old Jun 11, 2006 | 01:27 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: (Nateblizzy)
I just put the bolts back in and it was fine.
Old Jun 11, 2006 | 02:53 PM
__oversea's Avatar
eh? there should be 3-4 screws. take them off. and put the screws back.
Old Jun 11, 2006 | 03:22 PM
Default Re: Removing mud flaps.... (Last For One)
yea i figured out what the problem was in the rear...the plastic that "lines" the wheel well was missing, and i was unaware there was supposed to be something there. sooooo to replace that plastic piece missing i had to remove and modify the rear mud flaps only and bolt these "cut down" mud flaps to replace the plastic lining.
In the front, yea i just took them off and put the 3 screws back in to hold the plastic lining in place.
problem already solved.
zjknicks
Dec 9, 2015 05:01 AM
foxfai
Jun 12, 2008 10:18 AM
Ghost Shadow
Paint and Body
Sep 5, 2007 05:02 PM
krz6jdm
May 10, 2006 04:11 AM
Wrath of VTEC
Mar 8, 2003 08:43 PM
