removing the head
Old Apr 10, 2007 | 07:55 PM
92civic_si's Avatar
Default removing the head
searched and found nothing..
Question: is there any other way to remove the head without removing the camshaft? i don't want to remove the camshaft coz i don't want to mess-up the settings etc.. i head it's possible but the head is going to be heavy.
ohh if you have the link to how to install/remove b18 head..can you please give me the link..
thanks
Old Apr 10, 2007 | 07:57 PM
WGFletch4WS's Avatar
i dont see hwo it is possible since the head bolts are right under the cams but wat do i no
Old Apr 10, 2007 | 10:11 PM
unknown0001's Avatar
Default Re: removing the head (92civic_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civic_si &raquo;</TD></TR><TR><TD CLASS="quote">searched and found nothing..
thanks</TD></TR></TABLE>
Actually you cannot pull off the head without removing the cam shafts. Reason as stated below is because the camshafts 'cover' the head bolts...so you have no physical way of removing them without removing the camshafts first.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WGFletch4WS &raquo;</TD></TR><TR><TD CLASS="quote">i dont see hwo it is possible since the head bolts are right under the cams but wat do i no</TD></TR></TABLE>
you are 100% correct
Old Apr 11, 2007 | 12:41 PM
92civic_si's Avatar
Default Re: removing the head (Mr.RHTuner)
thanks for the info..so u can remove the head from a sohc but not a dohc then..thanks
Old Apr 11, 2007 | 01:01 PM
2ndgentegracer's Avatar
^You are correct.
ej1252
Oct 28, 2007 03:29 PM
91preyludesi
Nov 18, 2005 07:21 AM
Firestarter
Nov 5, 2005 01:30 PM
B_CRUZ!
Jan 10, 2002 10:49 PM
