Removing DOOR PANEL help...
Old May 1, 2005 | 05:33 PM
PhantomX's Avatar
Default Removing DOOR PANEL help...
Hey guys... some Idiot just hit my friends car and we need tips on how to take off the front door panels so we can try to bump it out.... i tried searchin the forums and got nothing.... any tips or links will help.. thankx guys...
Old May 1, 2005 | 05:39 PM
jBj's Avatar
jBj
Default Re: Removing DOOR PANEL help... (PhantomX)
On my 2dr there's one screw in the lower handle and one in the handle/latch to open the door, then just get your fingers under the edge somewhere and pull. its just a bunch of plugs holding it on.
Old May 1, 2005 | 05:52 PM
Educator's Avatar
Default Re: Removing DOOR PANEL help... (jBj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jBj &raquo;</TD></TR><TR><TD CLASS="quote">On my 2dr there's one screw in the lower handle and one in the handle/latch to open the door, then just get your fingers under the edge somewhere and pull. its just a bunch of plugs holding it on.</TD></TR></TABLE>
and a plastic one towards the front of the panel. Pull outwards on the panel and then lift up. The panel should slide off fairly easily.
Old May 1, 2005 | 06:03 PM
jBj's Avatar
jBj
Default Re: Removing DOOR PANEL help... (Educator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Educator &raquo;</TD></TR><TR><TD CLASS="quote">
and a plastic one towards the front of the panel. Pull outwards on the panel and then lift up. The panel should slide off fairly easily.</TD></TR></TABLE>
the one towards the front of the panel is a plug as well though, there is only two actual screws u will need a screwdriver for.
Old May 1, 2005 | 07:15 PM
Gs-rGuy's Avatar
i just did that today. taking them off isn't too bad, but make sure when you put them back on, you take off the small plastic piece that covers the wires to your mirror. it will make it so much easier.
Old May 1, 2005 | 08:28 PM
PhantomX's Avatar
Wow quick reply... thanks alot guys....
Old May 2, 2005 | 09:59 PM
PhantomX's Avatar
Default Re: (PhantomX)
Oops forgot to mention..... is it the same on 4 doors? preferably the rear doors....
Old May 2, 2005 | 10:05 PM
SPOONup's Avatar
Pulling them off is the easy part .. putting them back on might be more of a challange.
khmrdreamieboix
18
Feb 10, 2008 09:52 PM
ivanson
Feb 21, 2005 06:19 PM
SPOONup
Apr 13, 2004 08:00 PM
milkeyisback
Dec 20, 2003 07:04 PM
SoCar
Nov 18, 2003 01:37 PM
