i need help, i cant take my door pannel apart :(
I need to take my door apart. can anyone describe where the screws are on the door, or find me a tutorial. I have a 93 civic 4dr. I searched the forums and tried taking it apart myself but it wont budge..
Moderator
Re: i need help, i cant take my door pannel apart :( (milkeyisback)
take screw out behind door handle (inside) take screw out from arm rest....take plastic screw out near where it rest's against the dash...
then on bottom rear of door pry your fingers behind and pull really hard....
Screw behind handle (on inside) lever
Screw inside hand cup
Clip ring for non pwr window/ plug for pwr
start at the bottom of the door panel with a flathead for leverage, slip your hand in there and start gently popping out the plastic lock nipples....
Should be enough to get you through it...
Re: i need help, i cant take my door pannel apart :( (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">
then on bottom rear of door pry your fingers behind and pull really hard....</TD></TR></TABLE>
Haha.. no **** huh, I said gently
USDM DC4
05-19-2007 06:19 PM
