removing abs
Old Aug 25, 2008 | 03:06 PM
95_red_dc's Avatar
Default removing abs
I am about to remove my abs and I was would like to know the part numbers for the new brake lines from integra rs and what ever else I need.
Old Aug 25, 2008 | 08:16 PM
95_red_dc's Avatar
Default Re: removing abs (95_red_dc)
bump anyone know I want to make sure its the right part when ordering
Old Aug 25, 2008 | 08:19 PM
Haleiwa-Brando's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95_red_dc &raquo;</TD></TR><TR><TD CLASS="quote">I am about to remove my abs and I was would like to know the part numbers for the new brake lines from integra rs and what ever else I need.</TD></TR></TABLE>
I'm sorry...normally I don't give a ****, but may I ask you why you are removing the ABS?
For parts numbers: http://www.barancoacura.com
Old Aug 25, 2008 | 08:25 PM
barhonda_delsol's Avatar
i just removed my abs. probably removing it because abs is gay i drove my b16 delsol for two years and then got my 99 teg with abs and hated it. always kicked on two early so bye bye abs. i used brake lines of a civic ex with a 40/40 prop valve all works good. feels better then ever.
Old Aug 25, 2008 | 08:32 PM
95_red_dc's Avatar
Default Re: removing abs (Haleiwa-Brando)
I messed up the abs when I was doing the wire tuck. Plus I did not really care for it since my motor is being rebuilt I'm gonna just remove the whole system. And to clean the engine bay up more!
Old Aug 26, 2008 | 01:28 PM
jonshonda's Avatar
Community Builder
http://www.team-integra.net/fo...earch
There you go, and good luck with the deletion, it should be fun!!
Old Aug 26, 2008 | 01:43 PM
95_red_dc's Avatar
What about all the wires for the abs I would also like to remove all of those. Is there a write up on how to? And where is the abs computer located at?
Old Aug 26, 2008 | 01:54 PM
racebum's Avatar
i can understand abs deletion on a drag car or if you live in a place where it snows 10 months out of the year. for everyone else it makes no sense what so ever. i can't even begin to say how idiotic "abs kicks in too early sounds". the abs computer uses wheel speed sensors to detect skid in the tires. if you feel the pedal pulse a tire would be skidding. abs is hands down faster in autocross and the road course. it's also safer on the street. if you want better braking use better pads and stickier tires. if that still isn't enough use aftermarket brakes and R compound tires. all of which work with ABS !
Old Aug 26, 2008 | 03:04 PM
95_red_dc's Avatar
ok I've got the abs computer removed along with the whole harness for it all the way up to the orange plug by the firewall that connects to the main harness. The orange plug that is on the main harness could I just snip that plug off that connected to the abs computer harness? Since it would just be sitting there not connected and of course tape off the the wires.
Old Aug 26, 2008 | 03:05 PM
SleeperGSR's Avatar
Default Re: removing abs (idrivesideways)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idrivesideways &raquo;</TD></TR><TR><TD CLASS="quote">i can understand abs deletion on a drag car or if you live in a place where it snows 10 months out of the year. for everyone else it makes no sense what so ever. i can't even begin to say how idiotic "abs kicks in too early sounds". the abs computer uses wheel speed sensors to detect skid in the tires. if you feel the pedal pulse a tire would be skidding. abs is hands down faster in autocross and the road course. it's also safer on the street. if you want better braking use better pads and stickier tires. if that still isn't enough use aftermarket brakes and R compound tires. all of which work with ABS ! </TD></TR></TABLE>
I couldn't agree more. especially since it's a 99. When abs first came out in the 80's and some cars from the early 90's yeah it didn't really work quite right yet. But they bugs got worked out quick, i drive a 96 gsr auto-x and track very close to the limits and i've never had a problem with the abs kicking in to early, it's actually very hard for me to tell when it is "on" and when it isn't under braking. 100%Show car, to clean up the engine bay sure take out the abs. 100% Drag car, yeah take it out. Outside of that, i'm going to have to say leave it in. If it's not broke don't fix it.
Old Aug 26, 2008 | 03:08 PM
95_red_dc's Avatar
Default Re: removing abs (SleeperGSR)
Well I explained early that I did a wire tuck and ever since then my abs has not worked! If it did work I would not be doing this, and also my motor is out being rebuilt so I decided it would be a perfect time to take it out.
Old Aug 26, 2008 | 05:14 PM
95_red_dc's Avatar
bump I need some help please from some one that removed the abs wires before. What should I do with orange abs plug attached to the main harness?
Old Oct 17, 2008 | 07:59 PM
90tegblueonblack's Avatar
Yo you don't need to do anything insane, i have a ninety teg gs, all came with abs, except for the rally sport (rs) it has a proportional valve, get that, ebay, or junkyard
anyways, you know that already but, you don't need to change your booster or your master cylinder, or brake lines, your old lines can be bent to fit into the valve just be wise about where you put it, all sensors can be removed, you can remove your computer, all wires, everything, and it should reduce about fifty pounds, the orange plug can be cut and stripped, if i were you i would wait, and remove everything you want to and then go ahead and customize your harness its not difficult, just download a pdf for the diagram and color codes and remove all unnecesarry wires, re coat, you can get it at auto zone and tuck, way cleaner look, and setup
just trying to lend a helping hand
Old Oct 17, 2008 | 08:20 PM
95_red_dc's Avatar
Default Re: removing abs (90tegblueonblack)
A little late my removal of abs was successful! thanks 4 the help
Old Oct 17, 2008 | 11:03 PM
racebum's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95_red_dc &raquo;</TD></TR><TR><TD CLASS="quote">A little late my removal of abs was successful! thanks 4 the help </TD></TR></TABLE>
one more teg thrashed
Vcastro
Oct 13, 2006 08:46 AM
JimmyAtlantis
Dec 8, 2005 10:38 AM
rochnyteg
Jul 15, 2004 12:49 AM
bgod
Aug 19, 2003 09:27 AM
