redline problem
Old Jul 12, 2004 | 06:27 PM
Danethomp's Avatar
Default redline problem
i've got a 90 integra w/ a b18c1 block, jdm itr internals, and complete itr head. i'm using a pr3 ecu. problem is i'm hitting redline at around 7200 where it should be 8200 w/ the stock b16 pr3 ecu. any ideas? i'm getting a cel for the oil pressure. however w/ my vafc vtec will still engage. apparently the ecu pin is not staying in the plug all the way which is throwing the code. will this be causing the early redline? i'm pretty sure it's not the ecu that's bad because i swapped it w/ another pr3 and it's doing the same thing.
Modified by 90g2ls at 2:12 AM 7/13/2004
blackcivic20
Honda Civic (2001 - 2005)
Jun 15, 2007 07:40 PM
nickcrx
Oct 18, 2005 08:45 AM
zCivic
Apr 25, 2004 05:06 PM
zCivic
Mar 10, 2003 12:20 PM
