Redline?
Old Mar 19, 2003 | 03:35 PM
Gummy Joe's Avatar
Default Redline?
I want to know if this is possible. Its probably very newb question but is it possible to have 10k redline? i know the s2k has 9k redline, but i was wondering if anyone has any expertise on high redline theory. How and what do you have to do to go pass 9k redline. Im planning to just do ls/vtech.
Thnx
Old Mar 19, 2003 | 03:40 PM
Henry HA's Avatar
HAnda-Tech Member
Default Re: Redline? (Gummy Joe)
are u wearing a flame suit?
Old Mar 19, 2003 | 03:41 PM
xteg95's Avatar
Default Re: Redline? (B18C_DC2)
haha...what you need to redline at 10k for? even if you could im sure it wouldnt be to safe on a ls/vtec conversion.
Old Mar 19, 2003 | 03:43 PM
Gummy Joe's Avatar
Damn my bad *puts on the flame suit*
Old Mar 19, 2003 | 03:49 PM
lshobo's Avatar
if an s2k doesn't need a 10k redline, i don't think an ls/vtec will. still, i think it's possible, yet highly impractical.
Old Mar 19, 2003 | 03:52 PM
Sukebei Oni's Avatar
Default Re: Redline? (lshobo)
i think inline 4 sells a spoon built motor that will rev to 11k.
but i could be wrong.
gsxr's Avatar
get a motorcycle if you wana go past 10k
Old Mar 19, 2003 | 04:06 PM
MooreBoost's Avatar
Default Re: Redline? (gsxr)
Chip/Pistons/Rods/Springs/Retainers/and maybe cams if you wanna make any power up there, and fuel enrichment.
Im sure I missed something, but thats my stab at it anyway.
Ohh, and its Vtec by the way.
Old Mar 19, 2003 | 04:08 PM
MooreBoost's Avatar
Nothing needs a really high redline. Nothin needs 500whp, but its still very nice to have.
gmoore
Old Mar 19, 2003 | 04:12 PM
Pimpin Stef One's Avatar
Default Re: Redline? (gmoore379)
check out this vid...
http://www.importhustler.com/images/...ckredline.mpeg
Old Mar 19, 2003 | 04:14 PM
lshobo's Avatar
gmoore
true! well, if the man wants to rev up to 10k, when in fact his power might drop off somewhere at 8-8.5k, more power to him. i was merely speaking of the impracticality of it, especially on a motor that was not factory built for the purpose.
Old Mar 19, 2003 | 05:31 PM
.RJ's Avatar
.RJ
If you want a 10K redline and want to make power and be reliable up in that end of the rpm range its going to require alot of money, and its certainly a diminishing return. Stock fuel cut is under 8500 rpm for a GSR/ITR and those engines arent making power in that range (it drops off). Ever driven a S2K? Go do that and tell us how cool the 9K redline is driving around town...... I'd trade a big fat midrange torque curve for a 9K redline anyday.
Old Mar 20, 2003 | 06:40 AM
Xscream's Avatar
Default Re: Redline? (.RJ)
Jimmy Johnson had a small block chevy that was turning huge power from 5k all the way to 10.5
If you don't know who Jimmy J. is he is a world famous NHRA drag racer.. As was posted before this cost - a lot to say the least
Old Mar 20, 2003 | 06:51 AM
btl fed's Avatar
Default Re: Redline? (Xscream)
I know rotary engines, like in the RX-7, can turn like 12k rpm
Old Mar 20, 2003 | 01:59 PM
ThrillaKilla's Avatar
cams and valve train upgrades can set you a little higher with tuning and adjustments...
Old Mar 20, 2003 | 02:20 PM
combustion's Avatar
It is possible toda stage 3 cams you are going to want to balance that crank change your rods, pistons, valves retainers, valve springs. hmmmmm let me think but should not be to much more than that. Oh yea you may want to sleeve your block to take that kind of stress.
Old Mar 20, 2003 | 02:28 PM
DeafNgari's Avatar
Default Re: Redline? (combustion)
Kinda a silly question... reving to anything is possible. I am not trying to be mean but by asking it it shows you dont know diddly about how your engine works or at least little, but the good thing is you care enough to ask. Read read read... become one with your b seris engine. If you learn the in and outs of it then you will have a good basis to learn about pretty much any other engine there is out there. They are relatively the same. I strongly suggest you visit http://www.teamintegra.com and check out their articles. Most are very well written. Some are long reads but its worth it.
Old Mar 20, 2003 | 02:34 PM
.RJ's Avatar
.RJ
Default Re: Redline? (btl fed)
Not on the street or track. 8-9K is all you will see. Dont spread misinformation.
Old Mar 20, 2003 | 02:44 PM
bitzbp's Avatar
Default Re: Redline? (Pimpin Stef One)
Nice vid!! That thing moves.
Old Mar 20, 2003 | 03:41 PM
SuzukaBlueAP2's Avatar
Technically, rotary engines will never stop revving. There is no red line on them. The tach just has numbers with no red zone. However, a light comes on the dash that tells you when you should shift right quick or else you're gonna shred your alternator. Because you'll actually destroy a pulley on those motors before you over-rev it.
Home Wrecker
Mar 9, 2006 09:26 PM
Mugencrxsir1
Feb 1, 2006 10:39 PM
sikcivic95
54
Dec 1, 2004 11:48 PM
Blind-Fashion
Aug 4, 2004 01:31 AM
untitledsn41
May 19, 2004 07:39 PM
