ls/vtec help!!
Old May 19, 2004 | 06:35 PM
untitledsn41's Avatar
Default ls/vtec help!!
what should a ls/vtec redline at. my friend just bought a gsr with a ls/vtec in it...im wondering what it should rev up to because the tach says 8000 is redline but i know its not that high. please help me out
Old May 19, 2004 | 06:37 PM
hi mom's Avatar
Default Re: ls/vtec help!! (untitledsn41)
I would get some sort of limiter at 7600...
Mine hits vtec at 4700 and redlines at 7600 with chipped ecu
If its stock, dont go higher then 7600.. if its not, then you could go anywhere up to 8 or even 9 if its built..
Whats the stats?
Old May 19, 2004 | 06:43 PM
mrxracing's Avatar
i would think you would be around 8200 with the conversion.
i have also heard that the rods have a hard time eventually dealing with that if they are stock ls
rods. but not 100% sure
Old May 19, 2004 | 06:50 PM
im just going to tell him 7500. rather be safe than sorry. thanks guys.
oh its a stock ls/vtec with just short-ram/exhaust.. his vtec kicks in at 5900
Old May 19, 2004 | 06:51 PM
hi mom's Avatar
Default Re: (untitledsn41)
5900 vtec? haha whatt he hell for?
If your max power ends at 7600 why vtec so late?
You might want to get a Spoon or VAFC and map that down a hell of a lot more dude..
Old May 19, 2004 | 06:55 PM
i told him to get a VAFC and lower it to 4900-5000.. but he just got the car a couple days ago
Old May 19, 2004 | 06:56 PM
he wants an alarm and a system first...but i'll talk him into gettin one soon. i just told him about it and he claims its fine for now....IMO i think he should get it asap
Old May 19, 2004 | 06:57 PM
hi mom's Avatar
yup, as far as being stock..
the engine will not handel very much rev at 8000... even 7700 is pushing it
with the setup he has right now its about 9.2 to 1 compression, very very low, if you want to rev up higher you might want to bump it up with SIR or CTR ITR pistons..
like I said, stay away from the 8's, keep it around mid 7 range..
Good luck guys..
btw: asap oil/water from gsr .. pick them up and install them, your going to regret it later on if you dont...
Old May 19, 2004 | 07:00 PM
J337_UNIT's Avatar
Default Re: (Kid RS)
honestly IMO the best way to see where you should shift at is put it on a dyno.. wherever your car makes its peak power at, is roughly where you should be shifting.. that is IF your bottom end can handle it however.. if its stock bottom end i wouldnt shift past 8 really but thats just my 02 cents.
Old May 19, 2004 | 07:04 PM
hi mom's Avatar
Default Re: (J337_UNIT)
my car is stock ls/vtec, intake and exhaust..
It went on the dyno and we set the rev limiter at 7600 and vtec at 4700, no matter how much better you may think it could be.. its probably around the exact same, go over 7600.. hell, tell him to hit 9000 and then well talk when it blows up..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kid RS &raquo;</TD></TR><TR><TD CLASS="quote">btw: asap oil/water from gsr .. pick them up and install them, your going to regret it later on if you dont...</TD></TR></TABLE>
talking about oil and water pump?...
Old May 19, 2004 | 07:39 PM
hi mom's Avatar
yes, if the car is non-vtec to begin with, your going to want to upgrade to oil and water pump from a GSR... highely reccomended
97civic94gsxr
Mar 11, 2008 07:21 AM
Cain Marko
Apr 4, 2004 03:36 PM
ALLMTRWHORE
Jan 29, 2003 11:37 PM
