Rebuilding the engine
Old Sep 8, 2010 | 07:31 AM
TekBuDDy's Avatar
Default Rebuilding the engine
Ok so i have. 95 ls motor with 110xxx miles. My car burns oil like no other i smelling it in the car and a cloud of smoke when i come to a stop. I did q compression test cylinders 1,2 are low so i came to the conclusion its my rings.
My question is when i do the rebuild should i replace parts with oem or just go to autozone
Parts to replace are:
rings
rod bearings
head gastket
all seals (inc valves)
mayb oem pistons
and arp head studs
timing And water pump was replaced about 5k ago or less
Whats brands would be ideal fo daily drivig. And mayb a lil boost next yr.
Old Sep 8, 2010 | 08:27 AM
TekBuDDy's Avatar
Default Re: Rebuilding the engine
bumpppppp
Old Sep 8, 2010 | 09:55 AM
milkmanLCA's Avatar
cant go wrong with oem
Old Sep 8, 2010 | 01:18 PM
1998GsRIntegra's Avatar
Oem for the simple reason that the quality is much better than just about any after market part because Honda has to warranty all of their parts.
Dj Hack
Nov 5, 2014 02:42 PM
killudie123
Oct 2, 2012 04:14 PM
Vsm Hatch
Dec 30, 2004 12:16 AM
int3gra
Jun 24, 2003 09:36 AM
