Rear disk pad replacement
Old Sep 27, 2002 | 12:45 PM
Charged R's Avatar
New User
Default Rear disk pad replacement
Anything special to know about changing rear disk brake pads on a GSR? I've changed the front before, never the rear. NO specials tools needed, right?
thx
Old Sep 27, 2002 | 12:46 PM
Rory Breaker's Avatar
Default Re: Rear disk pad replacement (Charged R)
You use a c-clamp on the front, but you have to turn the rear piston, if I remember right.
Old Sep 27, 2002 | 12:48 PM
Charged R's Avatar
New User
Default Re: Rear disk pad replacement (newgsrdriver)
Yep, I've used C clamp to get enough clearance to stuff a new pad into the front. Does turning the rear piston require a special tool? thanks
Old Sep 27, 2002 | 12:54 PM
Charged R's Avatar
New User
Default Re: Rear disk pad replacement (2000integragsr)
Sorry to be so dumb here, I don't have a manual. Do you use the screwdriver to push the piston back in, or do you actually turn some a large screw.
thanks. (on my head)
You dont need a special tool. I used a large screw driver.
Dont forget to get the high temp brake anti-sqeak grease.
Old Sep 27, 2002 | 01:30 PM
civickidd99's Avatar
I've changed the rears on my 91 ls integ and all I did to compress the piston was to use a pair if needle nose pliars, see the piston has a recessed cross on it and you just put the tips of the pliars in the slots and rotate clockwise
Old Sep 27, 2002 | 01:35 PM
cjohnson_2's Avatar
Default Re: Rear disk pad replacement (hfracing)
I just did mine last week. really pretty simple.. just look closely at it the stuff is pretty straight forward. Dont forget to put some disk brake quiet on the back of your pads so they dont squeek..
Old Sep 27, 2002 | 02:24 PM
Charged R's Avatar
New User
***thanks all
Old Sep 27, 2002 | 03:39 PM
eh-D's Avatar
Don't rip the boot, don't rip the boot, please don't rip the boot!
Old Sep 27, 2002 | 05:33 PM
LostGsr's Avatar
Default Re: Rear disk pad replacement (eh-D)
Do you need to do anything special with the parking brake?
Old Sep 27, 2002 | 05:49 PM
eh-D's Avatar
Default Re: Rear disk pad replacement (LostGsr)
Make sure it is off when you are taking the brakes apart, but I put it back on when dropping the car, so it won't roll back.
Ezduzit2500
Jun 11, 2018 05:21 PM
NACvicSi
Sep 5, 2009 12:15 PM
Si GUY99
Aug 5, 2007 12:54 PM
twotone
Oct 11, 2002 05:11 PM
D
Aug 6, 2001 06:21 AM
