radiator support/clutch
okay today as i was exiting out the school... the car was cold didn't let it warm up.. rev was at 2k. i forgot my car is dropped 2.75" so i was going down driveway and boom!! my lower radiator support smacked the floor... i was so mad.. it scared the **** out of me.. do u think i may have bent it sumwhere along the rails? cuz i look underneath the car and everything looks fine.. i popped hood to check if everything in place.. looks fine.. does anybody think the rad support is tough metal?
Re: radiator support/clutch (soon2bdropped)
also i think my clutch needs to be replaced because.. its getting hard now to get the shifter into gear.. theres like some resistance.. but i don't get it.. clutch doesn't slip and i can take off wit no gas.. i don't get it..
I would worry less about the thick metal support and more about the plastic bumper, hope there's no damage to that. If everything seems to be lining up good then I wouldn't worry. 2.75" drop is scary since bottoming-out can happen a lot!
As for your clutch issue, depends on how many miles you've put on it, but I would make sure that tranny fluid isn't too old and that it is at the correct level for starters.
d16y8EL
15
04-26-2005 02:12 PM
