Radiator question
Old May 27, 2002 | 05:48 PM
Nighthawk GS-R's Avatar
New User
Default Radiator question
ok as some of you know, i got into an accident and well one of the thing needed to get replaced is the radiator.. should i go with a stock one or a fluidyne? whats the benefits of an aftermarket one? also im hoping ot be able to get a jdm front end out of this so id prefer to get the cheaper one , but what ever......
thanks
Old May 27, 2002 | 08:00 PM
Ri5e's Avatar
Default Re: Radiator question (Nighthawk GS-R)
Fluidyne. Thats what I have. Because the stock one, its gonna run you like $300 from Acura. So might as well spend $50 more and get a polished Aluminum Fluidyne.
Old May 27, 2002 | 08:18 PM
IN VTEC's Avatar
Check and ask around for a used one in the classifieds and on ebay. You also might wanna look at what Import Auto Salvage has.
http://www.importautosalvage.com
I wouldn't pay more than $110 for a used Integra radiator. Prices have averaged out to around $100 for a used one, and been pretty steady in price fluxation.
Old May 27, 2002 | 09:31 PM
Tweakmeister's Avatar
Acura ones are plastic capped on the top and bottom. They are prone to cracking (albeit mine didn't crack until 116k!). You can get one from http://www.1888radiator.com/ for $141 and it's the same quality as OEM (have one here next to me).
Or the solid aluminum Fluidyne. It's very sweet and won't crack. Costs a little more though.
[Modified by Tweakmeister, 6:32 AM 5/28/2002]
Old May 28, 2002 | 04:03 AM
stick's Avatar
get OE ITR rad. its all aluminum then get the FAL slim fans too
Old May 28, 2002 | 06:22 AM
IN VTEC's Avatar
I can also look into C&R radiators. They're located in Indianapolis and just an hour away from me. I gotta go to the Ack dealer today and pick up some parts. I'll stop by.
edit: http://www.crracing.com
http://www.crracing.com/estore/produ...port_radiators
[Modified by IN VTEC, 11:25 AM 5/28/2002]
Old May 28, 2002 | 06:30 AM
Drew M's Avatar
New User
You can get *nice* stock radiators from junkyards for $75-$90. If you can afford the Fluidyne go with it however. The stock units all separate at the tank seam. They are lovely under-engineered pieces of **** so if you can stay away from them do so. Even the ITR radiator is built in the same fashion so it too is subject to this failure.
One thing to remember about the Fluidyne is that it only has bosses for 1 fan. If you have A/C still you will probably want to have someone TIG weld a second set of bosses or come up with another method of mounting the fan.
[Modified by Cobra, 10:31 AM 5/28/2002]
Old May 28, 2002 | 06:38 AM
zilverz's Avatar
ahh i see you have a GSR your fine (: if you had an AUTO tranny you would need a special radiator with an Auto TRanny cooler in the bottom of it
Old May 28, 2002 | 07:46 AM
wonny's Avatar
Default Re: Radiator question (zilverz)
Or just get an additional tranny cooler.
Old May 28, 2002 | 08:04 AM
zilverz's Avatar
Default Re: Radiator question (wonny)
more parts/hoses that could go out and frag your transmission ... keep it simple and like the factory design if you ask me ... as far as the tranny cooler is concerned
Old May 28, 2002 | 09:42 AM
ndustryalGSR's Avatar
I'm very happy with my Fluidyne. However, unless you need the additional cooling capacity (which, of course, I don't), you might be better served replacing it with a stock-like radiator. The Fluidyne sure is pretty, though. I was lucky enough to have bought mine when they were on special: $272, shipped to my door.
Old May 28, 2002 | 10:01 AM
dasher's Avatar
One thing to keep in mind about the Fluidyne is that it is wider than the Oem radiator... If you want to use a large turbo you are going to have to relocate your fans in front of the Radiator so they push instead of pull.
Old May 28, 2002 | 02:36 PM
New User
Default Re: Radiator question (dasher)
is the itr radiator different? how so? '
one quick question about the fluidyne...........how hard is it too install? any benefits?
Old May 28, 2002 | 03:04 PM
ragejed's Avatar
benifits? looks great. cools better
Old May 28, 2002 | 05:21 PM
mingchi96
Guest
Posts: n/a
Default Re: Radiator question (ragejed)
do yourself a favor.. and buy a B&B radiator. Their number is (214) 341 3000. I have had one on my b20/vtec for 3yrs + and that thing has done nothing but good. they have a lifetime warranty also, and they only cost less than $100 shipped to you... Im sure. Do not spend $300+ on a fluidyne when this B&B radiator will do the same job. Trust me. They are great radiators.
You definately do not need higher cooling capacity. It will do you nothing.
[Modified by mingchi96, 2:23 AM 5/29/2002]
civics4lyfe
12
Jan 25, 2009 09:57 AM
SpankyG
Nov 22, 2005 11:29 AM
EuN_TeK
Mar 29, 2005 02:22 PM
worditsmenick
Aug 19, 2004 09:27 AM
s6139
Jan 19, 2002 02:12 PM
