Radiator Problem..Need Help
Old Sep 10, 2005 | 12:59 PM
frank358fr's Avatar
Default Radiator Problem..Need Help
Hi everyone,
I found a crack in the lower bottom of my radiator(see picture). Yet, it's new from Jan of this year. How can it be repaired or did I need to buy a new one. The reason being that itis plastic and not metal. Thanks for your help.
Frank
Old Sep 10, 2005 | 01:32 PM
EMJAY's Avatar
dont worry man this is a common prob with our radiators. i would replace with an aluminum one.
Old Sep 10, 2005 | 02:34 PM
the_23rd_letter's Avatar
Default Re: (kb12)
i had the stem on the cap crack... and melt... and then proceed to spray coolant all over my engine bay and over heat my poor little car. I was steaming like mongolian BBQ. seriously get this fixed soon, and as KB12 said, go with aluminum.
Old Sep 10, 2005 | 02:51 PM
LL2009's Avatar
Default Re: (the_23rd_letter)
those radiator are plastic they cant be fixed , you can get a new one or get used one fron a junk jard or if you have the cash get an aluminun that will fix your problem
Old Sep 10, 2005 | 07:51 PM
NuclearB18B's Avatar
Default Re: (LLEO245)
mine gave out at 108k miles. and my friend told me that i was luck that it even lasted that long. i used that as an excuse to buy a fluidyne. one piece of advise though, if you're ever planning on going turbo, think about what your plans are and get a radiator suitable for those needs. if i could go back, i would've bought a half size aluminum radiator. just my .02
Old Sep 10, 2005 | 08:57 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: (NuclearB18B)
You can get it repaired but I wouldn't even bother with those plastic POS radiators. Go to http://www.radiatorbarn.com and order the all-metal radiator and stop worrying about those plastic endtanks blowing out!
Old Sep 10, 2005 | 09:25 PM
gsr dood's Avatar
Default Re: (FrostyDC4)
hell man i had the same thing. my retarded brother jacked my gsr up by the radiator and put a 2 inch crack in it guess wat i fixed it with ......yep good old jb weld it was a little less than a year ago still no drips or nothing.....knock on wood
Old Sep 10, 2005 | 10:29 PM
Johnny_Rocket's Avatar
Default Re: (gsr dood)
I bought a half size aluminum radiator for my teg... I think it was actually for a civic but either way... it worked great with my turbo setup.
Old Sep 11, 2005 | 05:51 AM
Racermech's Avatar
Default Re: (JohnnyH)
at least go all metal if you dont have the $$$$ for the aluminum
jfresno
Apr 1, 2009 11:16 AM
IgnitionZ05
May 5, 2007 10:50 AM
dadado
Oct 25, 2004 07:09 PM
Vinhtran17
Apr 26, 2004 11:46 AM
BluLuder
Jul 29, 2002 11:29 AM
