A quick Write-Up on the Differences in B18b1 Heads (pr4 and P75)
Old Oct 19, 2008 | 06:29 PM
SOHCD16y8's Avatar
Default A quick Write-Up on the Differences in B18b1 Heads (pr4 and P75)
Hey guys, It seems that time and time again I see people (including myself) posting up questions looking for difference between the OBD-1 Pr4 head and OBD-2 P75 head. I have a couple of each laying around, and decided to take a quick looksy.
As we all know, the b18a/b/b20 heads can be switched out with no modifications necessary. This is with the exception of the p8r head, but Im not including that.
On with what I found,
First thing I looked at was inside the valvetrain casting in the head. Overall everything is the same. The only difference I can see is that the p75 head has a 4th oil return to the pan, while the pr4 has more of a vent hole.
Pr4 on the right, p75 left
Picture of the p75 oil return
Pr4 oil return Vent
The next thing I did was take a quick measure of the intake and exhaust ports to look for any noticeable differences. It has been brought up before that the p75 has bigger ports that flow better, but I failed to see nythign different. I measured quite a few different surfaces, and everything was identical between the two. Im no professional, but if there is a difference I didnt see it.
Intake Port
Exhaust Ports
Next up, I took a look at the head surface of the two heads. This is where I found the most difference between the two. As can be seen from the pictures, the p75 has much larger coolant ports than the pr4. However the pr4 has on additional port on the return side of the cooling system, the p75 does not have this. The chambers in both appear to be identical.
Pr4 left, p75 right
Pr4 head
P75 Head
P75 Center Cooling Jacket
Pr4 Center Cooling Jacket
The last thing I looked over was the cams. Once again, there have been claims of slightly bigger cams in the p75. From what I found, the lift on both appears to be the same. I had no good way to easily test duration, but if there is a difference it is minor
Pr4 on the right
Overall, an easier to give to someone is that the heads are identical. If your really worried about cooling, the p75 appears to be a bit better, but deck rigidity may be sacrificed a very small amount. The ports also appear to be identical. When it comes down to overall performance, they should be the same.
Hope this helps answer someone questions.
Old Oct 19, 2008 | 06:47 PM
B204door's Avatar
good [freak]en write up... real interesting
Old Oct 19, 2008 | 07:14 PM
5hift9ears's Avatar
good write up on this topic.
Old Oct 19, 2008 | 07:40 PM
jhammond_82's Avatar
Reject Papi
Default Re: (5hift9ears)
faq worthy i would think.
Old Oct 20, 2008 | 08:19 AM
thatblkguy's Avatar
was that the sec gen pr4 head or first?
sec gen pr4 cams are the the same as the p75
first gen's pr4's are not
Old Oct 20, 2008 | 09:36 AM
SOHCD16y8's Avatar
B18b1, so second Gen. This head in particular was a 1995.
I tried my best to make it clear that this is between the B18b1 heads. Its common knowledge that the B18a1 heads (and cams) are different.
Old Nov 3, 2016 | 05:04 PM
BoRiCuA's Avatar
Default Re: A quick Write-Up on the Differences in B18b1 Heads (pr4 and P75)
Sorry I actually searched, you mean to tell me that if i have a B18b1 block with a p75 head it is obd2? but it's had an obd1 dizzy the entire time, running good also........back from the dead so hopefully someone can answer.
Old Dec 5, 2016 | 08:40 PM
arwifl's Avatar
no the 94-95 ls integra I believe has a p75 head and is obd1.
Old Oct 29, 2018 | 01:00 PM
ulitegi's Avatar
i have obd1 b18b with low compression from a 1995 integra do you guys know if my obd1 head will work on a obd2 b18 block any differences in head gasket and will the extra oil return vent on obd1 head cause any issues since obd2 head doesnt have it?
pentaq
Nov 28, 2005 12:36 AM
baphomet
Sep 22, 2005 10:03 AM
HKSone
Apr 28, 2003 02:22 PM
