Quick Sway bar question
I found this sway bar on ebay, just wondering if this includes everything I would need to install it, or are there a few other things that I would have to pick up.
http://cgi.ebay.com/ebaymotors...wItem
Or am I better off buying something like this.
http://www.beaksproducts.com/DC_Quick_Swap.htm
I am open to any other suggestions, thanks alot.
I believe you need to get the beaks o ASR subframe reinforcement when going with a bigger rear sway bar. This is because non ITR's rear subframes are weaker and are more prone to tearing up.
Ali
Ali
So at the dealer I can order the USDM type R sway bar new? and then I pick up the bushings and the brackets there as well? Does anyone know the part numbers for this? I'm confused about what I would be buying from beaks. I guess I need to know exactly what parts I need to bolt the sway bar on.
1.) 52300-ST7-Z01 rear swaybar (80 something
2.) 52315-ST7-Z01 swaybar bushing ($4.40) (2 needed)
3.) 52308-SS0-000 bushing bracket ($5.95) (2 needed)
4.) 52316-ST7-Z00 endlink bushing ($1.75) (2 needed)
5.) 52312-ST7-Z00 endlink bushing collar ($4.90) (2 needed) –– this part can be reused from the stock swaybar
6.) 90175-ST7-Z00 bolt (8x35) ($2.45) (2 needed)
7.) 94050-08080 flange nut (8mm) ($0.50) (2 needed)
8.)BSQ kit or Beaks............
Parts 6 and 7 are only needed if you buy the bsq kit.
You also <U>need</U> the beaks or bsq install kit. Without it your subframe will tear out and you will be in a serious world of hurt. Take the time to do it right. Just go to beaks website and order the kit for the dc, just the install kit, without the swaybar, it's 75 bux or something. Or you could get the package deal, it's really up to you.
Oh ok, so I want to buy parts 1-5 that you listed, and this
http://www.beaksproducts.com/S...t.htm
or this which includes everything I need
Andrew 825SM
Jul 7, 2003 01:19 PM
