Quick question about engine bay cleaning
Old May 24, 2004 | 10:01 AM
cashmoneystu's Avatar
Default Quick question about engine bay cleaning
Has anyone had any problems with their engine starting after cleaning out their engines with gunk- or engine bright foam. I know that i should cover both the distributor cap and throttle body, but is there anywhere else that water can sneak in that i should know about and cover? and also for the throttle body they mean to just cover the opening that the air intake is attatched to right so i don't get hydro-lock when i start the car?
Old May 24, 2004 | 10:03 AM
Kendall's Avatar
I would cover up the plugs going into the starter and the alternator just to be on the safe side.
Old May 24, 2004 | 10:07 AM
Default Re: (Kendall)
And how about any of the electrical wires and battery terminal wires?
Old May 24, 2004 | 10:50 AM
Xymox007's Avatar
Default Re: (cashmoneystu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cashmoneystu &raquo;</TD></TR><TR><TD CLASS="quote">And how about any of the electrical wires and battery terminal wires?</TD></TR></TABLE>
Yes, cover them as well. Plastic bags from the grocery store work quite well for this task. Don't get carried away with engine bay cleaner/degreaser.
Old May 24, 2004 | 10:51 AM
shamoo's Avatar
Will you make something up for me please?
You don't need to worry about those. If you want to, you can disconnect your battery, but you don't have to. Just put some tape over your distributer seam, and don't spray too hard where the spark plug holes are.
You can go nuts with the water everywhere else. Spray the battery, alternator, wires, harness, anything and everything. You'll be fine. Just let everything dry nicely after you're done.
Old May 24, 2004 | 11:58 AM
furious94ls's Avatar
Default Re: (shamoo)
tin foil works well on the alternator, starter.
Old May 24, 2004 | 12:05 PM
Default Re: (furious94ls)
Thank you all for the help- i am now done with my successful engine cleaning and it started and ran fine first try. I checked the distributor and intake and no water had got into either w/ the simple cling-wrap and rubber band technique.
Old May 24, 2004 | 12:07 PM
Xymox007's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by furious94ls &raquo;</TD></TR><TR><TD CLASS="quote">tin foil works well on the alternator, starter. </TD></TR></TABLE>
Hahahaah! Good one!
baller14k
Detailing
Oct 1, 2011 05:19 PM
mynameizstitch
Jul 3, 2009 09:24 PM
951dc5
11
Apr 15, 2008 12:53 PM
jdm_dc_fan
Jun 30, 2006 01:50 PM
Standard One
Feb 8, 2004 01:02 PM
