quick question ....
Old Dec 13, 2002 | 07:03 AM
PTL's Avatar
PTL
Default quick question ....
my car got wierd noise and shaking on the front left tire when im braking around 60 miles . Frist i thought it was the left cv joint broke but i friend told me was my left disc rotor warp . What u guy think? and my check engine flash about 10 times when i started the car , is it ok?
[Modified by PTL, 4:46 PM 12/13/2002]
Old Dec 13, 2002 | 07:05 AM
NeoGSR's Avatar
Default Re: quick question .... (PTL)
sounds like a warped rotor to me
Old Dec 13, 2002 | 08:16 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: quick question .... (killerlime)
It's definitely your rotor. Just get them turned, cost should be like $20 or so if you take them off yourself. About $50 if you have them do it.
The light that's blinking isn't your Check Engine light. It's your maintenance required light. That comes on automatically at set intervals from the factory that just remind you to take it in for it's regular service (oil changes, etc). First it will start to blink...then after a few days, it will be constantly on.
You can either take it to the dealer to have it serviced with whatever is scheduled at that mileage or you can do the work yourself. To turn off the light, feel under the dashboard under the steering column where your knees are. There should be a square button. Hold that down for a few seconds and the Maintenance Required light will turn off.
Good luck.
Old Dec 13, 2002 | 11:23 AM
PTL's Avatar
PTL
i will fix them rotors and check my car this weekend if i got time thanks guy
apple88599
Oct 21, 2006 09:19 AM
pens81
Acura TSX
Mar 30, 2006 03:42 AM
Corruption
Apr 28, 2005 11:15 AM
casmello
Apr 7, 2005 04:02 AM
francfurter
Dec 29, 2004 08:47 PM
