Quick Question
I have a 97 LS with a 97 B20b block. im getting CEL number 54 which is:
54 96-98 Civic 97-98 CRV 94+ Integra CKF Sensor (Crankshaft Speed Fluctuation) defective circuit or unplugged / defective sensor now i noticed on the LS block there was a plug connector by the crank pulley that wasnt on the b20 block. is this a big deal and is anyone else having this problem? im using the LS wiring harness and LS ecu... someone please help me out. |
Re: Quick Question (2SLO)
ttt
Was your car running well before you found this?
your getting that because your LS ecu thinks there should be a sensor there. as for your engine i don't know if it will cause problems, it probably will. I would suggest getting an ecu that is compatible with the b20 or even if you could find a piggyback that can lie to the LS and make it think everything is ok, that would work.
