QUICK QUESTION!!!!!!
Old Oct 21, 2008 | 12:12 PM
96 hatch's Avatar
Default QUICK QUESTION!!!!!!
is it possible/safe to pour transmission fluid down the vent hole opening? --->
I dont have a really long extension to remove the bolt that holds the vss.
thanks for any replies
Old Oct 21, 2008 | 12:40 PM
96 hatch's Avatar
Default Re: QUICK QUESTION!!!!!! (96 hatch)
BUMP!!!
Old Oct 21, 2008 | 12:50 PM
qazaq's Avatar
it's gonna take you forever, plus you wont have any other opening for the air to come out when you refill. so might as well fill it up the proper way
Old Oct 21, 2008 | 02:21 PM
berb_15's Avatar
Default Re: QUICK QUESTION!!!!!! (qazaq)
You're also not going to know how full it is either. I'd try to do it properly, there has to be someone around with the right tools you can borrow from. Goodluck
Old Oct 21, 2008 | 02:26 PM
hmongyaj87's Avatar
Default Re: QUICK QUESTION!!!!!! (berb_15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by berb_15 &raquo;</TD></TR><TR><TD CLASS="quote">You're also not going to know how full it is either. I'd try to do it properly, there has to be someone around with the right tools you can borrow from. Goodluck </TD></TR></TABLE>
b-series tranny usually takes 3 and a half quarts of tranny oil. there's a plug on the passenger side of the tranny. use a ratchet to open it up ( i forgot what size) and that should let air get out as the fuids go down that little tube. wont take as long and when you see oil flowing out of the hole on the side, you should be pretty much 3 and a half quarts which means you are full.
Old Oct 21, 2008 | 02:40 PM
Mfoehrkolb's Avatar
i used that when i filled mine up! worked fine. I just used a bottle, with a long piece of vacuum hose connected to it that went into that bunge. A+ for me.
Old Oct 21, 2008 | 02:42 PM
BoSox46GSr's Avatar
Default Re: (Mfoehrkolb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mfoehrkolb &raquo;</TD></TR><TR><TD CLASS="quote">i used that when i filled mine up! worked fine. I just used a bottle, with a long piece of vacuum hose connected to it that went into that bunge. A+ for me.</TD></TR></TABLE>
Same here... should be fine.
Old Oct 21, 2008 | 03:32 PM
Status R's Avatar
Default Re: (BoSox46GSr)
you should fill it from the proper hole so that you fill it the proper amount also. just buy a small hose and have a friend fill it from up top while you lay under the car to monitor the level and make sure the hose stays in the tranny
Old Oct 21, 2008 | 04:14 PM
danthemang3's Avatar
Default Re: (Status R)
you don't have to remove the vss. there is a drain and fill hole right next to each other.
Old Oct 21, 2008 | 04:15 PM
you don't have to remove the vss. there is are two seperate plugs right next to each other. one for draining and one for filling.
Old Oct 21, 2008 | 05:04 PM
Jimmy's Avatar
Global Moderator
Default Re: QUICK QUESTION!!!!!! (hmongyaj87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmongyaj87 &raquo;</TD></TR><TR><TD CLASS="quote">
b-series tranny usually takes 3 and a half quarts of tranny oil. there's a plug on the passenger side of the tranny. use a ratchet to open it up ( i forgot what size) and that should let air get out as the fuids go down that little tube. wont take as long and when you see oil flowing out of the hole on the side, you should be pretty much 3 and a half quarts which means you are full. </TD></TR></TABLE>
B-series tranny's hold 2.3 quarts..
You can use 10w-30 conventional motor oil, honda MTF, gm syncromesh/friction modified (if they still make it) or pennzoil synchromesh..
also why the 3 post's?
Old Oct 21, 2008 | 07:49 PM
Default Re: QUICK QUESTION!!!!!! (Jimmy)
sorry about that my internet was being gay! it stayed on the same page after i hit the button so somehow all three went at once. oh well whatever.
Old Oct 22, 2008 | 08:07 AM
b18c1ej8's Avatar
Default Re: QUICK QUESTION!!!!!! (danthemang3)
they take 2.2 quarts and the easiest is to put it through the speed sensor
Old Oct 22, 2008 | 08:17 AM
steveharrmr23's Avatar
Default Re: QUICK QUESTION!!!!!! (b18c1ej8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1ej8 &raquo;</TD></TR><TR><TD CLASS="quote">they take 2.2 quarts and the easiest is to put it through the speed sensor</TD></TR></TABLE>
is how i did it was well
Old Oct 22, 2008 | 01:50 PM
hmongyaj87's Avatar
Default Re: QUICK QUESTION!!!!!! (steveharrmr23)
my bad. i forgot it was 2.2 quarts, i was thinking of motor oil.. lol.. it's been awhile since i changed mine.
Old Oct 22, 2008 | 07:07 PM
EARLdaSQUIRREL's Avatar
official honda whore
its funny you say that becuase the vss is always a bitch for me to get out, i just use a funnel with a hose and fill it through the 17mm hole that is for monitoring how full the trans is
that way when its full it drips out a little bit and i quit filling it
rodvang
10
Jan 19, 2006 09:19 PM
JRizEJ6
Jul 21, 2005 07:27 PM
Weston
12
Jan 3, 2005 04:51 PM
TheGSRGuy
Acura TSX
Jul 25, 2004 04:58 PM
DCFIVER
Mar 10, 2004 04:55 PM
