Quick question
Old Nov 8, 2006 | 01:41 PM
Tizight's Avatar
Default Quick question
So I installed a new thermostat today in my b20 and after I bled the coolant and did everything by the book. I took her out for a drive and I came back and only the upper raidiator hose is hot and the lower is not as hot. I took it for about a 5 minute drive. Is this normal or did I install it wrong. I replaced the thermostat and made a gasket perfectly.
Old Nov 8, 2006 | 02:22 PM
Tizight's Avatar
bump come on kids
Old Nov 8, 2006 | 02:46 PM
sport_injected_prelude's Avatar
Default Re: Quick question (Tizight)
it should be fine, is the temperature guage working.
Old Nov 8, 2006 | 02:58 PM
turboxxxs's Avatar
i think your all good! the coolant has already been cooled by the time it gets to the lower hose.. just keep an eye on your temp. gauge on the dash, and listen for your fan to kick on, about 5 min. after the car starts
Old Nov 8, 2006 | 03:17 PM
Tizight's Avatar
My fan is broken and I run fine without it. Thanks for the replies
Old Nov 8, 2006 | 09:40 PM
Tizight's Avatar
bump
Old Nov 9, 2006 | 05:51 AM
VtecAdvantage's Avatar
after a termostat install you should run your car for 10-15 mins with the rad. cap off to make sure it works.
but, if the thermostat is pointing to the radiator then you should be fine, just remember to check ur coolant level
Houston1995bt
Jul 29, 2015 06:12 PM
Ef4doorwagon
11
Mar 17, 2014 09:16 PM
xolk88
10
Mar 18, 2010 05:18 AM
ImPuLsIvE
Oct 25, 2007 04:08 PM
M2B4
Apr 20, 2006 09:56 AM
