Quick question...
Old Feb 9, 2005 | 11:17 AM
AutoEuphoria's Avatar
Default Quick question...
What is the stock throttle body inlet diameter for a GSR?
Old Feb 9, 2005 | 11:22 AM
AllMotorGSR94's Avatar
62 mm i do believe
Old Feb 9, 2005 | 11:24 AM
Default Re: (AllMotorGSR94)
so a bored tb to 64mm wouldn't change much then?
Old Feb 9, 2005 | 11:25 AM
.brian.'s Avatar
Default Re: (AutoEuphoria)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">GS-R Throttle Body
2.635" Inlet OD
2.714" Inlet Lip OD
2.368" = 60.1mm Throttle Plate OD
2.397" Outlet ID
All measurements were made with a dial caliper precise to .001".
Old Feb 9, 2005 | 11:31 AM
Default Re: (i luv my 97 teg)
So would a 13% increase in intake area be worth $100?
Old Feb 9, 2005 | 12:00 PM
CNSK's Avatar
I have a 64mm bore throttle....no difference but every little thing will help....
Old Feb 9, 2005 | 12:56 PM
95lstegman's Avatar
Default Re: (CNSK)
stock GS-R, SiR-II, 92+ LS, and CRV is 60mm. and if you visit maxbore.com i think it is, he can do you for +4mm. in that case it's 12.2% increase. just FYI, you can go a long way just doing a nice smooth venturi before the plate. like make the entrance large and slowly blend it down into the 60mm throttle.
PS: 60mm is the plate size. the inlet end is like 62mm, but the plate is only 60mm.
Old Feb 13, 2005 | 04:26 PM
Default Re: (95lstegman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95lstegman &raquo;</TD></TR><TR><TD CLASS="quote">and if you visit maxbore.com i think it is, he can do you for +4mm. </TD></TR></TABLE>
Jorge just did mine, excellent work.
jdm styles
Mar 18, 2007 09:25 PM
FyReo3
May 21, 2005 07:03 AM
cjames235
Welding / Fabrication
Feb 3, 2005 05:36 PM
wushubrian
Jan 25, 2005 09:27 AM
GSxRated
May 9, 2002 04:57 PM
