Quick Question.
Old Nov 4, 2004 | 04:25 PM
RicharDC4's Avatar
Default Quick Question.
i just need a quick question answered.
im saving up money right now to buy full coilovers for my LS. but the thing is is that i dont know how much inches i should drop to get the tires to "tuck". im asking this because i might buy the Edelbrocks IAS inverted coils that drop a max of 2.5 inches. is 2.5 enough to tuck my tires? if it isnt, i might go for the omnipower coils that can go as low as 4 inches.
im running on 2000 LS meshes and tires are 195/55-15
TIA.
i tried searcing already.
Old Nov 4, 2004 | 04:29 PM
kwoksturr's Avatar
Default Re: Quick Question. (RicharDC4)
i think 2 inch would tuck in the tires, if not then its pretty close to being tucked.
Old Nov 4, 2004 | 04:32 PM
RicharDC4's Avatar
Default Re: Quick Question. (kwoksturr)
yea thats why i posted my rims and tire sizes.
if you didnt see it its LS meshes which are 15 inches and the tires are 195/55-15
stevieteg's Avatar
2.5 inches will be more then enough for a tuck. My car is dropped about 2" and the top of the tire is about level with the fender, 1/4 panel. remember the lower you go the more negative camber your gonna have. I'd suggest a camber kit either way.
Old Nov 4, 2004 | 04:52 PM
aku2085's Avatar
yeah 2.5 inches is more than enough i have a set of cheap old coilovers that came with my car when i bought it and they weren't proporly damper with the stock shocks so then when i bought my new coilover kit and took off the tires i saw some serious rubbing inside the wheel walls.
Old Nov 4, 2004 | 04:56 PM
Calsonic's Avatar
You should get a camber kit if you're gonna be that low.
Old Nov 4, 2004 | 04:57 PM
97hatchback's Avatar
2.0 to 2.5 will be ok, but you need a camber kit bad or you gonna have some serious tire balding on one side of the tire.
Old Nov 4, 2004 | 10:06 PM
RicharDC4's Avatar
Default Re: Quick Question. (97hatchback)
never really thought about it but what does a camber kit actually do?
does it fix rubbing against side walls or fix negative camber that wears tires unevenly?
beat ignition
Mar 21, 2014 11:08 PM
Shirozu
Apr 25, 2009 04:56 AM
ShawnbobHatch
10
Dec 12, 2008 11:28 PM
coupedup
Aug 18, 2005 06:44 AM
Toms96GSR
Aug 4, 2002 10:04 PM
