quick Q about header install...
Old Mar 21, 2003 | 12:25 PM
SupaTegRS's Avatar
Default quick Q about header install...
I have a dc sports 4-2-1 2piece header that I might try to put on over the weekend. My question is can I reuse the gasket between the engine block and header? My car is a 94 RS, and it is probably original gasket. Thx in advance
Old Mar 21, 2003 | 12:27 PM
StyleTEG's Avatar
Default Re: quick Q about header install... (SupaTegRS)
That gasket tends to be ok to reuse, but personally while I was at it I would just replace it. Its much easier to replace it since you are removing the header anyways, than having to replace it later because its leaking.
Old Mar 21, 2003 | 12:30 PM
SupaTegRS's Avatar
Default Re: quick Q about header install... (IntegRaVeR615)
ok, I'll definately just go ahead and replace it....thx for the quick response guys
Old Mar 21, 2003 | 12:31 PM
Eva01's Avatar
I would just replace it since it's a 9yr old gasket. Shouldn't be more than a couple bucks. Besides wouldn't it be a pain in the *** if the old gasket happens to leak. Then you have to take the header off again and get a new gasket to replace the old one which you should have done in the first place.
Old Mar 21, 2003 | 02:02 PM
typeR#0427's Avatar
Default Re: quick Q about header install... (Eva01)
just remember to go back through and re-tighten the bolts again. That will make the seal perfect with a new gasket. I installed mine about one month ago and it took about 2 hours. Good luck
Old Mar 21, 2003 | 02:22 PM
tilt's Avatar
Default Re: quick Q about header install... (hamB18C1)
I re-used my gaskets on my crx and teg. No probs.
Old Mar 21, 2003 | 02:41 PM
x00gsr's Avatar
Whats the tightening procedure on headers?
Old Mar 21, 2003 | 02:47 PM
typeR#0427's Avatar
Default Re: quick Q about header install... (x00gsr)
[/QUOTE] Whats the tightening procedure on the headers? [/QUOTE]
Start in the middle and work your way out one side at a time. Left, Right, left, right, etc. to the outside. I don't remember the ft/lbs on it it though. Thats how I have done the last 3 that I installed. And I have had no problems at all.
[Modified by hamB18C1, 4:48 PM 3/21/2003]
Old Mar 21, 2003 | 11:38 PM
GSRaCeRbOI's Avatar
seeing that its a 94 and you have the header apart anyway.. you might as well go ahead and put in a new gasket.. it doesn't cost that much and its much easier to put in a new gasket than to put in your header only to discover a leak.. then have to take it apart and do it all over again... just get a new gasket and save yourself some time and worries...
gtowni3
29
May 12, 2005 03:14 PM
JonnySBeee...
Jan 15, 2005 10:18 AM
Broken Gearbox
Oct 24, 2003 10:49 PM
sombasol
Jul 2, 2003 01:17 PM
Toda
Jun 27, 2002 11:00 AM
