QUICK & EASY ABS CONVERSION
Old Jun 14, 2008 | 05:17 PM
ice-burg-slimm's Avatar
Default QUICK & EASY ABS CONVERSION
I just completed my conversion on my DC GSR,and all i had to get was,
1. 40/40 prop valve
2. EG civic FR/FL brake lines
3. flaring tool
4. brake line tube bender
5. tube cutter
You will keep the original MC & BB.The only line you will need to cut,bend and flare is the line coming from the right side of the MC that as the big fitting.Once you have every thing hooked up bleed the brakes and your done.
NOTE:your brake bleeding prosses can be easier and quicker if you have a compressor.
Old Jun 14, 2008 | 06:25 PM
TurbdEG6's Avatar
Default Re: QUICK & EASY ABS CONVERSION (ice-burg-slimm)
if you are trying to do some sort of write-up pictures help...just for future reference
trillzilla
Suspension & Brakes
Oct 17, 2015 04:56 PM
Wdpfreak145
10
Mar 28, 2013 10:48 AM
spencedogg
Oct 4, 2003 09:44 PM
Roger
Jul 2, 2002 05:07 AM
