question need help asap
Old Oct 13, 2008 | 10:42 PM
sLAg's Avatar
Default question need help asap
ok i have an LS with the og b18b and for some reason oil seems to go into the holes were the spark plugs go,
oil goes up to the top of the spark plug thats the highest ive seen it go and its only on the 3 of them,
the farthest one just yesterday wen i cheked it barely started having some
so i got some napkins and started taking oil out
but cant figure out whtz causing it can any one help
i dont want my teggy to die
Old Oct 13, 2008 | 10:48 PM
Jintegragsr97's Avatar
Its your valve cover spark plug gasket. When you remove your valve cover there will be 4 rubber rings (gasket) preventing oil from going into your sparkplug holes. Just go buy new 1's or just buy ultra grey gasket maker for 5 bucks from autozone and put it on.
Old Oct 13, 2008 | 11:15 PM
sLAg's Avatar
Default Re: (Jintegragsr97)
i just bought some last week so it has em on but still oil goes in could it be ne thing else
Old Oct 13, 2008 | 11:21 PM
AlphaQup's Avatar
Default Re: (sLAg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sLAg &raquo;</TD></TR><TR><TD CLASS="quote">i just bought some last week so it has em on but still oil goes in could it be ne thing else</TD></TR></TABLE>
Did you use Hondabond or Permatex Ultra Grey on the new seals?
Old Oct 13, 2008 | 11:25 PM
sLAg's Avatar
Default Re: (AlphaQup)
no i bought some gaskets thats what i mean
Old Oct 13, 2008 | 11:37 PM
AlphaQup's Avatar
Default Re: (sLAg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sLAg &raquo;</TD></TR><TR><TD CLASS="quote">no i bought some gaskets thats what i mean </TD></TR></TABLE>
I understand that part. If you have not applied any Hondabond or Permatex UG on there, open it back up and apply a good dab on all 4 seals.
Do you happen to have any broken or stripped VC studs? That could also cause the seals to leak due to the lack of pressure needed for a tight seal.
Old Oct 14, 2008 | 12:17 AM
sLAg's Avatar
thanks doode for the info ill try it out hopefully it stops cuz my motor smells\smokes a bit lol
rjmancia
15
Sep 13, 2008 08:57 AM
keychild486
Aug 15, 2008 04:12 PM
TaZ326
Feb 7, 2004 02:19 PM
Civic
May 8, 2003 08:09 AM
envious1320
Apr 19, 2003 04:16 PM
