ABS Light on
Old Aug 21, 2004 | 11:16 AM
FULL-REV's Avatar
Default ABS Light on
Hey guys I have a 1995 Accra Integra LS 5/spd and my ABS light is on. I just bought the car about a month ago but haven't driven it. I checked my ABS reservoir and it is WAY past empty... there is only like an inch of fluid in there. My question is does that reservoir use the same brake fluid as the regular brake system? And how do I get fluid in there.... There seems to be a tiny hole ... almost like only a pin can fit only...
Thanks
Old Aug 21, 2004 | 11:29 AM
timmy8151's Avatar
Default Re: ABS Light on (hondaevo)
Just remove # 12 & 11 and pour the fluid in.
Old Aug 21, 2004 | 11:34 AM
CBRF4i's Avatar
No special fluid, regular brake fluid will do just fine.
Old Aug 21, 2004 | 11:37 AM
FULL-REV's Avatar
ohhhhhh gotcha thanks alot! Hmm now need to go buy some brake fluid...
Old Aug 21, 2004 | 11:49 AM
FULL-REV's Avatar
ohh and by the way here are some pics of her...
http://www.carforumz.net/forum...b.jpg
already have my skunk2 mega power catback exhaust system and my skunk2 lowering springs... i'm looking for some koni yellows.. ohh and alot bought a type r wing that is getting painted.
Old Aug 21, 2004 | 12:02 PM
timmy8151's Avatar
Default Re: (hondaevo)
If adding fluid doesn't get rid of the code, you might need to pull the error code. It's the same method as getting a CEL code: http://bseries.net/html/garage/engcode.php
Old Aug 21, 2004 | 06:25 PM
red95integ's Avatar
low on brake fluid when i took off my caliper and alot of fluid leaked out when i turned th e car on the abs light was on. Put some barke fluid in and it will go off.
supermotothud
Nov 10, 2008 04:09 PM
paniaguae640
May 24, 2008 01:35 PM
Hybrid CRX
Jun 6, 2003 08:13 AM
dynamo
Nov 15, 2002 01:18 PM
hankd
Aug 14, 2002 04:27 PM
