question for LS/vtec with golden eagle conversion...
Old Nov 1, 2004 | 06:00 PM
tegsallgood's Avatar
Default question for LS/vtec with golden eagle conversion...
hey guys i need some help---
i am in the midst of installing my gsr head on my b18b block and im using the golden eagle conversion kit.. i know i have to tap for the oil line but i have no idea where? if anyone has a picture where i have to tap that would be amazing... thanks a lot
also can i run stock oil n water pumps...
Old Nov 1, 2004 | 08:17 PM
Default Re: question for LS/vtec with golden eagle conversion... (tegsallgood)
Old Nov 2, 2004 | 05:38 AM
hello0! i cant get my car running untill i find out! lol help please
Old Nov 2, 2004 | 06:26 AM
JDMFreak's Avatar
http://www.c-speedracing.com/howto.php
they used to have LS/Vtec build up but all i see is B20/Vtec almost same concept but it will give you an idea
Old Nov 2, 2004 | 06:30 AM
Default Re: question for LS/vtec with golden eagle conversion... (JDMFreak)
schweeet thanks man.
anyone else?
Old Nov 2, 2004 | 07:35 AM
GWInquisitor14's Avatar
im doing my ls/vtec right now, i can try to take some pictures tonite and show u where it goes. Make sure to use thread lock on the fitting into the head and pipe sealer on the line's threads. Were u able to get ur crank pulley off?
Old Nov 2, 2004 | 07:41 AM
Default Re: question for LS/vtec with golden eagle conversion... (GWInquisitor14)
are you using the golden eagle kit?
Old Nov 2, 2004 | 09:09 AM
Sack Master's Avatar
I have yet to see a golden eagle kit that doesn't leak. Not that I have ever done it myself so thats probably why it leaked . Good luck with it though. Hope it doesn't leak.
Old Nov 2, 2004 | 09:30 AM
Taristin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMFreak &raquo;</TD></TR><TR><TD CLASS="quote">http://www.c-speedracing.com/howto.php
they used to have LS/Vtec build up but all i see is B20/Vtec almost same concept but it will give you an idea</TD></TR></TABLE>
http://www.c-speedracing.com/h...c.php
Ls/Vtec
Old Nov 2, 2004 | 10:01 AM
Default Re: question for LS/vtec with golden eagle conversion... (Raa)
yeah i read that but with the golden eagle kit its different! thats why i need help with the kit! uve never seen a golden eagle kit that didnt leak? thats funny because ive never heard someone complain about it or say anyting bad about it at all... anyone else???
Old Nov 2, 2004 | 11:42 AM
Honda Logic's Avatar
man its the same ****, just tap the sensor on the back of the block...its that simple
Old Nov 2, 2004 | 08:27 PM
Default Re: (Honda Logic)
ive seen some ppl compain about the leaking, my compaint is that the head gasket seemed like it didn't line up exactly on the block. I thought they were going to give me the exact gasket, but they didn't. Are there differen style blocks that are 81 mm bore?
Old Nov 3, 2004 | 04:52 AM
Default Re: (GWInquisitor14)
no way golden eagle sends you a factory head gasket.. my gasket even came with honda stickers and part number it definitly should fit
Old Nov 3, 2004 | 03:53 PM
Default Re: (tegsallgood)
i havent been able to start the motor yet, but i hope it doesnt mess up a coolant or oil passage.
Old Nov 3, 2004 | 04:38 PM
keep me posted. im still waiting for some parts (p28 and my obd conversion
Old Nov 3, 2004 | 05:07 PM
heh yeah, ill take one for the team
Old Nov 7, 2004 | 05:53 PM
well sorry to bring to this thread up, but my golden eagle kit is leaking at the sandwahich adapter. Are u suppose to put locktite or or thread sealant on the thread that goes onto the block?
Old Nov 7, 2004 | 08:12 PM
unscrew it, rub some oil on the o ring, oh and make sure the o-ring side is the one facing the block.... and then screw it back on.. its not supposed to leak.. but make sure the flat side is facing out (away from the block)
Old Nov 8, 2004 | 05:24 PM
yeah i did all that, i installed it pretty much how u would install an oil filter.
Old Nov 8, 2004 | 06:12 PM
make sure the flat side is against the oil filter. is it leaking from the place between the oil filter and the golden eagle thing or is it leaking between that and the block
did u take it off and try again? make sure the nipple is installed flush and correctly
Old Nov 8, 2004 | 09:24 PM
the_0ne's Avatar
here u go
Old Nov 8, 2004 | 09:29 PM
the_0ne's Avatar
http://www.hondaswap.com/forum...ic=11
read....
Old Nov 9, 2004 | 09:30 AM
elf's Avatar
elf
Default Re: (the_0ne)
If the sandwich plate is leaking, you need to re-install it.
https://honda-tech.com/zerothread?id=933509
Old Nov 9, 2004 | 10:07 AM
RallyRedGT-V6's Avatar
ahaha is that just like a decoration in your room? that thing is CLEAN
Old Nov 9, 2004 | 12:59 PM
X-Mazda 3 Racer's Avatar
Default Re: (96integra)
Installation of the plate is critical, it must be done correctly. The unit will NOT leak if it is installed properly. I use this kit all the time without any trouble!!! Here, I will re-post something that I wrote on this before:
Be sure that the silver shaft / bolt that we supply in the kit fits into the center of the black sandwich plate. If this is not CENTERED, then it can leak. It must be installed properly.
Take the unit off the car, hold it with the o-ring facing you. The silver shaft / bolt should fit all the way into the center bore you see.
Flip it over and the built-in washer should be sitting flat on the sandwhich plate!
Get the unit onto the car. Tighten the bolt by hand until it stops. Back it off until the black sandwich plate moves freely. Wiggle it around while pulling it back toward you away from the block. If seats in and stops wiggling, then it is positioned correctly. While still pulling back on the plate, spin the bolt until it stops. Then follow the supplied instructions.
jimburt3rd
Dec 19, 2008 10:49 AM
jdmstylesi
Performance
201
Nov 13, 2008 03:00 PM
CSSMiketsi
May 16, 2008 09:26 AM
Superdragr45
28
Feb 10, 2006 12:10 AM
modifyORdie
Jan 3, 2006 02:31 PM
