question on integra dc header and o2 sensor
Old Oct 10, 2005 | 01:11 PM
racekar's Avatar
Default question on integra dc header and o2 sensor
on a 95 gsr the o2 sensor is in the cat right?
on the dc header there is also an o2 sensor? where do i put the o2 sensor on cat or header and which one do i plug thanks
Old Oct 10, 2005 | 01:13 PM
xteg95's Avatar
Default Re: question on integra dc header and o2 sensor (racekar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racekar &raquo;</TD></TR><TR><TD CLASS="quote">on a 95 gsr the o2 sensor is in the cat right?
On the 94-95's the only o2 sensor is on the header. 96+ has one on the header and cat.
Old Oct 10, 2005 | 01:48 PM
purplegsr's Avatar
Default Re: question on integra dc header and o2 sensor (xteg95)
No, it's a little more complicated -
94-99 GSR has no o2 on the header at all (94-95 will have 1 o2 on the cat, 96-99 has 2 o2 on the cat)
00-01 GSR has 1 o2 on the header (and one on the cat) - the header is exactly the same as a 94-01 LS, 94-95 LS cats have no o2 in them at all, 96+ have 1, just like the 00-01 GSR.
Old Oct 10, 2005 | 01:49 PM
1bad-eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xteg95 &raquo;</TD></TR><TR><TD CLASS="quote">
On the 94-95's the only o2 sensor is on the header. 96+ has one on the header and cat.</TD></TR></TABLE>Right, just before the cat. The 2nd gen has it higher up on the header.
Old Oct 10, 2005 | 01:50 PM
purplegsr's Avatar
Default Re: question on integra dc header and o2 sensor (1bad-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1bad-eg &raquo;</TD></TR><TR><TD CLASS="quote">Right, just before the cat. The 2nd gen has it higher up on the header.</TD></TR></TABLE>
Wrong on both counts, the 94-99 GSR HAS NO O2 SENSOR ON THE HEADER!
Also, the 90-91 Integras have the o2 on the leftmost runner so that you can see it from the engine bay, while the 92-93 has 1 o2 at the collector like the 94-01 LS and 00-01 GSR.
Edit- I totally mistyped, I was correct in my earlier posts, I meant to say the 94-99 gsr has no o2 sensor on the header, and 1 in the cat. You can see my erroneous original statement in the quotes below.
Modified by purplegsr at 10:35 PM 10/10/2005
Old Oct 10, 2005 | 01:56 PM
1bad-eg's Avatar
Default Re: question on integra dc header and o2 sensor (purplegsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr &raquo;</TD></TR><TR><TD CLASS="quote">
Wrong on both counts, the 94-99 GSR HAS NO O2 SENSOR ON THE CAT!
Also, the 90-91 Integras have the o2 on the leftmost runner so that you can see it from the engine bay, while the 92-93 has 1 o2 at the collector like the 94-01 LS and 00-01 GSR.</TD></TR></TABLE>My mistake, I'm talking about the 96 and up, my fault, I should've specified the years. Better detail, thanks for pointing that out to me.
Old Oct 10, 2005 | 04:29 PM
racekar's Avatar
so plug up the header o2 sensor basically for my 95 gsr
Old Oct 10, 2005 | 04:33 PM
gsrious's Avatar
F**ken... all this miss information. oem 94-95 gsr come with only 1 oxygen sensor on the FREAKEN CAT(hince the shorter header length)
Old Oct 10, 2005 | 09:36 PM
purplegsr's Avatar
Default Re: (gsrious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrious &raquo;</TD></TR><TR><TD CLASS="quote">F**ken... all this miss information. oem 94-95 gsr come with only 1 oxygen sensor on the FREAKEN CAT(hince the shorter header length)</TD></TR></TABLE>
this is correct, see my edit above, I mistyped the first time I typed in bold, but this information I posted toward the top was correct:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr &raquo;</TD></TR><TR><TD CLASS="quote">No, it's a little more complicated -
00-01 GSR has 1 o2 on the header (and one on the cat) - the header is exactly the same as a 94-01 LS, 94-95 LS cats have no o2 in them at all, 96+ have 1, just like the 00-01 GSR.</TD></TR></TABLE>
Old Oct 19, 2005 | 03:03 PM
dannykointegra's Avatar
Default Re: (purplegsr)
I'm putting a OBD2 GSR into my 94 LS and running a OBD1 ecu. Therefore I should buy a 00-01 GSR header? Thanks.
Old Oct 19, 2005 | 05:06 PM
95integrags-r's Avatar
Default Re: (dannykointegra)
If I were to use an obdII cat and use a plug and loctite would that work?? to pass smog and just have the sensor in one of the holes. one other question. When I got the cat it will only fit upside down but when its upside down it connects perfectly to my exhaust... actually my exhaust sit pretty low.
Old Oct 19, 2005 | 07:34 PM
purplegsr's Avatar
Default Re: (95integrags-r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dannykointegra &raquo;</TD></TR><TR><TD CLASS="quote">I'm putting a OBD2 GSR into my 94 LS and running a OBD1 ecu. Therefore I should buy a 00-01 GSR header? Thanks.</TD></TR></TABLE>
If you're running an obd1 ecu, just use a 94-01 ls header (easier to find), although a 00-01 gsr header is exactly the same, people will want more $ and there are fewer available. You will not need an o2 in the cat, so just use the 94 ls cat.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95integrags-r &raquo;</TD></TR><TR><TD CLASS="quote">If I were to use an obdII cat and use a plug and loctite would that work?? to pass smog and just have the sensor in one of the holes. one other question. When I got the cat it will only fit upside down but when its upside down it connects perfectly to my exhaust... actually my exhaust sit pretty low. </TD></TR></TABLE>
as long as you aren't using an obd2 ecu, plugging it up should work fine. If your cat is upside down, where is your o2 pointing? down at an angle?
Old Oct 19, 2005 | 07:41 PM
the O2 sensor wont even fit. thats why im going to an exhaust shop... to cut the flange and flip the cat so the O2 sensor will fit, unless someone can tell me whats going on.... cause it doesnt make sence that the cat is flipped like that.
Old Oct 20, 2005 | 08:58 AM
Nataku's Avatar
I have a 96 GSR and i just removed my cat yesterday... i had 2 o2 both where in the cat... so stop fighting.
4drgsr96
Dec 24, 2006 09:22 AM
project93accord
Feb 3, 2006 05:42 AM
phivelug
Jan 20, 2005 11:27 AM
dylokjai
Nov 23, 2004 11:11 AM
efjuice
Sep 14, 2003 11:14 PM
