o2 sensor location?
Old Dec 23, 2006 | 08:24 PM
4drgsr96's Avatar
Default o2 sensor location?
i've got a 2000 gsr engine, i was looking for a header at my local speed shop and when they asked what car i told them its was a gsr. they asked me where the location of the primary o2 sensor was and i told them it was at the of the stock header.
well they proceeded to tell me that i was not running a stock gsr header but that i had an ls header because both gsr o2 sensors are located directly on the catalytic converter and none are on the header.
can you guys give any input on this?
Old Dec 23, 2006 | 08:29 PM
Micha's Avatar
FAILWGN
Default Re: o2 sensor location? (4drhonda)
On a 2000, your primary is on the stock header.
Old Dec 23, 2006 | 09:04 PM
SimplyB18C1's Avatar
yeah on my 99 the primary o2 is right before the cat (you have to go under the car to see it) and there is one after the cat (that one just tells you if your cat is in working order) .
Old Dec 24, 2006 | 09:22 AM
gsr dood's Avatar
Default Re: (SimplyB18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SimplyB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">yeah on my 99 the primary o2 is right before the cat (you have to go under the car to see it) and there is one after the cat (that one just tells you if your cat is in working order) .</TD></TR></TABLE>
schumi
Apr 24, 2006 12:19 PM
racekar
Oct 20, 2005 08:58 AM
phivelug
Jan 20, 2005 11:27 AM
dylokjai
Nov 23, 2004 11:11 AM
wizzards581
Oct 5, 2003 12:29 PM
