Putting on side maker ?
ok guys i got me some sidemakers from passwordjm and it came with the harness and i want to put them on already...so my ? is where do i drill or cut on the fender? is there a guide that show where they go on the fender or where to cut the holes for the sidemakers. please i need some help cuz i dont want to cut in the wrong spot on my fender and mess it up.
-eddie
``who took my cookie....if i find out who took my cookie i will crush there souls``
-eddie
I just ran a quick search for sidemarker and came back with 30 results. Here's one I posted in.
https://honda-tech.com/zerothread?id=1833522
And what's up with the poll?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">
And what's up with the poll?</TD></TR></TABLE>
lol i thinkin that too..
that diagram above is what i used for my friends fender, people mistake it for jdm fenders cause its so fresh and so CLEAN!!! lol
I've been thinking about doing this for some time now.... I've almost talked myself into doin it
You guys using Honda markers or just some aftermarket ones that don't look like crap?
Modified by mac_24_seven at 10:49 AM 5/2/2007
you can put it anywhere you want, but you should put it in between the fender well and the door trim ( just on top of the side molding trim). you will need a hole drill bit for a clean cut.
ya thats what i was thinking just putting them anywhere in between! i got my sidemarkers from passwordjdm mang....
``aboout the poll.....lol....how the hell you write up a post without those polls showing up on your post? so i just write somethings in the polls....i dont know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mac_24_seven »</TD></TR><TR><TD CLASS="quote">I've been thinking about doing this for some time now.... I've almost talked myself into doin it
Modified by mac_24_seven at 10:49 AM 5/2/2007</TD></TR></TABLE>
New OEM DA from PasswordJDM on mine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PACT man »</TD></TR><TR><TD CLASS="quote">
New OEM DA from PasswordJDM on mine.</TD></TR></TABLE>
x2 for my EF (rectangular) and x3 for my friends DC (like and oval)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by My_EFsedan »</TD></TR><TR><TD CLASS="quote">
http://i74.photobucket.com/alb...7.jpg</TD></TR></TABLE>
Eh that's just a touch too far back. The front-most point on the sidemarker should line up vertically with the end of the bodyline crease in the fender below it. See my pic in the post I linked above.
DEFINITELY use OEM Stanley sidemarkers. I used to have imitation OEM ones (the ones that say SONAR on them) and they fit like ****. They required the same rectangular hole and had the same metal clip on the back of the sidemarkers, but for some reason they would not sit flush with the fender. Finally I spent $35 on a pair of OEM EG/DC sidemarkers from inlinefour.com and they fit perfectly.
As for cutting the hole, I took the diagram I linked in the post above (which is for an EG fender btw), drew out the hole in AutoCAD using the dimensions in millimeters, and printed it out. Then I taped it in the correct spot on the INSIDE of my fender, and scored the lines with an X-acto knife. I drilled a hole and then used a metal nibbler to cut out the shape, which is much MUCH easier, faster, cleaner, and quieter, and more precise than using a Dremel.
kirbyman
Paint and Body
13
Jan 28, 2008 07:33 PM
