PS removed
Old Apr 2, 2004 | 12:03 PM
No's Avatar
No
Default PS removed
I removed ps today.Because i like the way the feeling of driving my crx feels.I did notice a little power difference.It handles much better on the highway and higher speeds too.I think its a good free mod and prolly gave me 3 hp or so.Basically what a intake would do.Just letting anyone who is intrested too do it because you barely notice the difference.Well standing still its harder but going like 1 mph then turning its nothing
Old Apr 2, 2004 | 12:26 PM
SuzukaBlueAP2's Avatar
Default Re: PS removed (narib2oo1)
Glad you enjoy it also. I did it on mine a little over a year ago. Also switch crank pulleys.
Old Apr 2, 2004 | 12:53 PM
No's Avatar
No
Did you notice a difference at all with the crank pulleys?Im gonna rip out ac soon because it stoped working.So would the CTR pulley work good?
Old Apr 2, 2004 | 12:57 PM
TurBoTeG's Avatar
do a search on the CTR pulley. It does not have a harmonic balancer....Your best bet is to have your oem pulley machined down
Old Apr 2, 2004 | 01:46 PM
Default Re: (TurBoTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurBoTeG &raquo;</TD></TR><TR><TD CLASS="quote">do a search on the CTR pulley. It does not have a harmonic balancer....Your best bet is to have your oem pulley machined down</TD></TR></TABLE>
My CTR pulley is an OEM Honda part. It does have what is referred to as the "harmonic balancer". All it is is a rubber grommet-like ring on it. It absorbs some vibrations. It's 100% identical to my OEM pulley, minus the A/C and P/S.
The weight of the OEM pulley is approx. 11 lbs and this one is about 1.3.
Old Apr 2, 2004 | 04:34 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by narib2oo1 &raquo;</TD></TR><TR><TD CLASS="quote">I removed ps today.Because i like the way the feeling of driving my crx feels.I did notice a little power difference.It handles much better on the highway and higher speeds too.I think its a good free mod and prolly gave me 3 hp or so.Basically what a intake would do.Just letting anyone who is intrested too do it because you barely notice the difference.Well standing still its harder but going like 1 mph then turning its nothing </TD></TR></TABLE>
Did you actually remove the whole PS system and do the loop-back trick for the PS line connections on the rack? I have removed only the belt before and I didn't like it at all, steering felt VERY heavy most of the time. At slow speeds it was much harder to turn than a car w/ a manual rack because all that fluid and pressure was still in there and I had to fight it. I hope you did it the right way.
Old Apr 2, 2004 | 04:50 PM
W.O.P.'s Avatar
Default Re: PS removed (PatrickGSR94)
did you feel that whopin 3hp with your butt dyno? i didnt notice anything
Old Apr 2, 2004 | 04:51 PM
TurBoTeG's Avatar
https://honda-tech.com/zerothread?id=786465
Old Apr 2, 2004 | 05:14 PM
Kendall's Avatar
Regardless of whatever power gain there is, my car just felt a lot better during hard driving after I removed power steering.
Old Apr 2, 2004 | 06:33 PM
No's Avatar
No
no i just removed the belt.And for you people thinking its stupid, you pay 100-300 dollars too get the same results from a intake or header.Its free and i prefer the stiff feeling,i guess if your a wimp and not concerned about getting every last bit of power then its not good.But for a free mods along with weight reduction,they are excellent!Also car is so much better handling at higher speeds.
Old Apr 2, 2004 | 06:36 PM
Kendall's Avatar
You'll find the steering feel to be much easier with the entire assembly removed, or at least disconnected.
W.O.P.'s Avatar
Default Re: (narib2oo1)
yes you DO feel the road more BUT, it still is a gay way to gain TQ not HP. and my SR intake caost me $50 not 100-300. if your gonna be that cheap about upgrading your car and getting the little bit more power ahy do you even have a teg?
Old Apr 2, 2004 | 06:47 PM
No's Avatar
No
Default Re: (dohc VTEC eaaater)
WTF did you say???Hey kendall what exactly do i have too remove?I think its fairly easy already.Not like power steering but still.And yes too the moron who bought the intake for 50...GOOD FOR YOU,but theres tons of people who will pay 100-200 for an aem.Not too mention 300 for dc headers which prolly give you the same amount of power as removing the belt.Also if you want too run the ctr pulley you need too remove it.
Old Apr 2, 2004 | 07:05 PM
1993acuraintgralsvtec's Avatar
i took the ps out of my car and now the handling sucks, esp at slow speeds.
Old Apr 2, 2004 | 07:09 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by narib2oo1 &raquo;</TD></TR><TR><TD CLASS="quote">WTF did you say???Hey kendall what exactly do i have too remove?</TD></TR></TABLE>
You need to remove the reservoir, power steering pump, pump mounting brackets, main line, return line, and the cooling line that bolts to the front of the A/C condenser. Everything is fairly straightforward, Someone with no mechanical skill could get it done in an afternoon.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993acuraintgralsvtec &raquo;</TD></TR><TR><TD CLASS="quote">i took the ps out of my car and now the handling sucks, esp at slow speeds.</TD></TR></TABLE>
I should note that it takes time to get used to. The only aspects of the handling it will effect are driver input and driver feedback.
Old Apr 2, 2004 | 07:16 PM
No's Avatar
No
Great thanks man.Ill try it tommarow.Shouldnt take too long.Do i have too do loop that hose thing?I just searched about it and saw this.Any pics where it shows where this stuff is located?
Old Apr 2, 2004 | 07:29 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by narib2oo1 &raquo;</TD></TR><TR><TD CLASS="quote">Great thanks man.Ill try it tommarow.Shouldnt take too long.Do i have too do loop that hose thing?I just searched about it and saw this.Any pics where it shows where this stuff is located?</TD></TR></TABLE>
You can if you want to. It's primarily to keep dirt out of the steering rack. Get ahold of Padawan and tell him you're interested. I had his kit on my car until it was accidentally destroyed during an engine swap.
Old Apr 2, 2004 | 07:30 PM
No's Avatar
No
Cant i basically just have the hose and run it from the exit and enter parts on the rack and tie it down?Or is there more too it??
Old Apr 2, 2004 | 07:31 PM
No's Avatar
No
or could i just cap the ends of where i would put the hose?
Old Apr 2, 2004 | 07:32 PM
Kendall's Avatar
If you do that, then you get air in the system along with the fluid. The proper way is to loop it to a T fitting that goes up to a reservoir to keep a constant supply of fluid and keep air in the system.
Old Apr 2, 2004 | 07:36 PM
No's Avatar
No
possible too have any pics? I have seen it two ways... One where one line goes from the exit then another from the enter part on the rack too a T fitting and then into a breather filter.Everyone says just too loop the line over on the rack...?I dont know
Old Apr 2, 2004 | 07:42 PM
Kendall's Avatar
Don't worry about it. I'm not using anything on mine.
Old Apr 2, 2004 | 07:46 PM
No's Avatar
No
ok Great ill prolly just ghetto rig something up.Any thing too purchase when removing ac as well?I know there is gonna be a hole in the firewall where the condensor lines run too the black box behind the dash.I will probably do all the removing in one day
Old Apr 2, 2004 | 07:51 PM
Kendall's Avatar
No, I haven't heard of any A/C removal kits. It only took me half an hour to remove the entire A/C, though some of the lines are probably not reusable.
Old Apr 2, 2004 | 08:00 PM
W.O.P.'s Avatar
Default Re: (Kendall)
i just cut my A/C lines in front of the battery so you cant see them.
