Problems Jacking?
Old Aug 17, 2001 | 02:18 PM
Milfin69's Avatar
New User
Default Problems Jacking?
For any of you with the Eibach Pro-Kit/Koni Yellows, did you have any problems getting a floor jack under it, or using lifts in the garage with the 1.3"+ drop? I use a local garage with hydraulic lift but will get adjustable coilovers if this gets me too low. (I like the drive on push button convenience of a lift)
Lates
Old Aug 17, 2001 | 02:24 PM
98EX's Avatar
New User
Default Re: Problems Jacking? (Milfin69)
This is what you do, when you want to jac it up, get a couple of pieces of ordinay wood, drive up on them and voila, you car is now about an inch higher allowing you to get a jack under the car. If you need to take it to a shop, take the pieces of wood with ya, they're portable, they're lightweight, and very convienient. Foe $50 I'll sell ya mine---j/k
Old Aug 17, 2001 | 02:30 PM
LoneWolf's Avatar
New User
I saw this thread title....and it truly scared me.
Old Aug 17, 2001 | 02:32 PM
98EX's Avatar
New User
Default Re: Problems Jacking? (LoneWolf)
Man lone, I never thought of it like that, but I can understand what you mean.
Old Aug 17, 2001 | 05:05 PM
vteg's Avatar
New User
Default Re: Problems Jacking? (98EX)
The wood is a good idea. I always use the scissor jack to raise my car an inch and then use my floor jack. Oddly, my mechanics floor jack slides under my car with no problem. Wheels on the front of my jack are too big.
Old Aug 17, 2001 | 08:17 PM
Smurf's Avatar
New User
Sometimes it starts to lean to the left a bit. To compensate I use my other hand and after a period of time it starts to straighten out again.
Old Aug 17, 2001 | 08:46 PM
iNteGraz92's Avatar
Default Re: Problems Jacking? (Smurf)
hahahaha
Old Aug 17, 2001 | 09:37 PM
MintyDip's Avatar
Default Re: Problems Jacking? (iNteGraz92)
i do the wood trick too, Im on the koni yellow and prokit. The rear will jack uyp fine.
here is a picture.
Old Aug 17, 2001 | 10:16 PM
SlipAngleX's Avatar
Just use the factory jack to raise it enough to slide in your regular jack.
I use the factory tie down points in the front
Old Aug 18, 2001 | 12:09 AM
kento's Avatar
Default Re: Problems Jacking? (4DoorTeg)
put smaller wheels on the front of your jack.
Old Aug 18, 2001 | 04:24 AM
X2BOARD's Avatar
Default Re: Problems Jacking? (kento)
Wood ? Jacking? Fellas.... this is a PUBLIC forum !
Old Aug 18, 2001 | 04:44 AM
slowerthanu's Avatar
New User
Default Re: Problems Jacking? (X2BOARD)
I never have a problem Jacking, my favorite movie dim the light and a tube sock. All you need for a night of smooth jacking.
Old Aug 18, 2001 | 08:48 AM
sloazzbimmer's Avatar
Default Re: Problems Jacking? (slowerthanu)
i'm with you, the only Fast and Furious i like
732xghost
Apr 9, 2007 11:20 PM
Pompiuses
Sep 11, 2004 03:38 AM
showcarmike
Nov 18, 2002 06:26 PM
RacerXintegra2k
Sep 5, 2002 04:08 PM
AcuraFiend
Jun 17, 2002 02:31 PM
