Problem!!!! RPM question
Old Aug 21, 2004 | 06:07 PM
black_hatch's Avatar
Default Problem!!!! RPM question
98 GSR. Having problems with RPM. Will be unstable and will go from 1000 to 3000 when I am on idle. Acceraleration is very bad. I tried resetting ECU and and it helped but continued to do same as soon as I drive it. Any suggestions would be helpful. Cannot figure this out. It might be a simple vacuum leak too but cannot find it either.
Old Aug 21, 2004 | 06:17 PM
Default Re: Problem!!!! RPM question (black_hatch)
Can it be by any chance the sensor on manifold??????
Old Aug 21, 2004 | 06:59 PM
spoon-itr's Avatar
i had the same problem. It was a vacuum leak. now it idles from 600-1000. I got ripped though and it cost me 1000 at a local shop. yea i got ripped.
Old Aug 21, 2004 | 07:25 PM
matman4444's Avatar
Default Re: Problem!!!! RPM question (spoon-itr)
yeah you got ripped... i left of this intake mani plug thing when i was doing something, but i left it off and it would rev up to about 2800, then down to 1k then back up esc. then i opened the hood and saw... put it back on and it was all good
Old Aug 22, 2004 | 12:46 AM
Default Re: Problem!!!! RPM question (matman4444)
I pulled sensor off and reconnected it and it works fine but once I drive it, it goes back to reving up and down. Sorry about you getting ripped off. It happens when you are frustrated and the only place you can turn to -- is a local shop. I knew guys on this forum can help me out. So if I change the sensor it should be ok then -- I think it might have gone bad. Thanks for the replies. If this doesn't work I will see what others have encountered. Can't give up that easy. Am determined to figure this out even if I have to take my whole motor apart to see what it might be. lol
Old Aug 22, 2004 | 05:13 AM
DriveSideWays's Avatar
ya change the sensor first and then see if the problem disappears.
fadedgsr
Apr 5, 2008 03:30 AM
rice a roni
12
May 24, 2005 12:31 PM
JO3
May 14, 2004 05:28 PM
stRtypR25
Jan 12, 2003 03:09 PM
