Problem refueling
Old Feb 5, 2009 | 03:43 AM
4g63powered's Avatar
Default Problem refueling
I've recently had a problem getting a full tank at the pump. The nozzles always kick off a gallon or two before the tank is full, and I can't get tthem to pump any more. The pump will flow, but only for a second then kick off again. I know it's not the pump, as I've gone to several different stations and get the same result.
That leads me to believe it's something to do with the filler neck or the vent tube. Has anyone else had this problem? And if so, is there an easy way to fix it?
Old Feb 5, 2009 | 04:38 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Problem refueling
How do you know if it's a gallon or two before full?
I used to fill my tank the the BRIM every time, did that for over 6 years (visible fuel sitting right there at the filler door). After it clicks off, I would just stand there and barely squeeze the pump handle so it would go in very slowly.
But then I discovered this is bad for the fuel vapor return pipe coming from the charcoal canister in the engine bay. So for the past few months I've just been stopping when it clicks off, and my fuel gauge still pegs itself at the FULL mark. Although it doesn't stay at the full mark for as long as when I used to fill to the brim.
Old Feb 5, 2009 | 06:24 AM
neardon's Avatar
I'm a Jackass
Your guage could be off
Old Feb 5, 2009 | 07:50 AM
Well, last night after I fueled up the needle never reached full. And I reset my trip odometer each tank, and if I go by that instantaneous mileage, I'm getting 30-33mpg now, which is UP from the summer. Last night it only took 7.xx gallons, and the light was on. That was with 243miles since the last fill-up.
I'm thinking that might also be an issue. Does the low fuel indicator light run off the gauge itself or the float in the tank?
Old Feb 5, 2009 | 08:38 AM
neardon's Avatar
I'm a Jackass
The gas light goes off the guage. The guage in my integra was pretty far off, like a quarter inch gap between the needle and full when it was topped off. I would go 50-100 miles with the tank pegged on empty. I didn't want the hassel of dropping the tank and changing out the float or whatever it could've been so I just lived with it, maybe its just a guage issue and not the float though?
Old Feb 5, 2009 | 10:14 AM
I'd have to drop the tank to get to the float? (sorry, I've never had to fuss with the integra; I'm used to working on DSMs and you dont have to drop the tank.)
It reads full when it's full, I think it just might read E too soon. That is, have a 8 gallon sweep rather than a 12.
I think I should be able to go a distance while on E, just based on the size of the tank and the average mileage I get, I'm just scared to push it too far.
juba_x
Aug 25, 2012 08:12 PM
tronic
Honda CR-V & Element
Dec 4, 2011 07:24 PM
sc0braj
Oct 4, 2008 02:15 PM
B-SerioUs EGg
Jan 16, 2006 08:36 PM
PyroVTEC
Apr 10, 2002 10:02 PM
