problem with my teg
Old May 3, 2002 | 05:35 PM
shovell's Avatar
Default problem with my teg
ok my car is idling low and shaking slightly while it idles, any suggestions on what could be wrong?
Old May 3, 2002 | 05:50 PM
blkbeast's Avatar
New User
Default Re: problem with my teg (shovell)
did you recently add anything to your car (mods)? try resetting your ecu.
Old May 3, 2002 | 07:40 PM
Weston's Avatar
I noticed that mine occasionally idles a little lower than normal after I installed an intake. Resetting the ECU didn't fix the problem. I also experienced a little shaking every so often at idle when my valves were out of adjustment.
Old May 9, 2002 | 02:01 PM
shovell's Avatar
Default Re: problem with my teg (Weston)
i still don't know whats wrong, anybody else have any suggestions?
Old May 9, 2002 | 02:10 PM
PM-Performance's Avatar
does it just do it when the car is cold or 1st started up?
mine does that too , no biggie
Old May 9, 2002 | 02:25 PM
Fooser's Avatar
Default Re: problem with my teg (itr206)
My car does this as well. I have gone thorough and inspected all the tubing for air leaks. I think my exhaust system might have a leak somewhere so im going to check the ghaskets next. Another possibility is timing. if your timing is off enough you can have a bad idle.
Old May 9, 2002 | 02:34 PM
Cone's Avatar
Default Re: problem with my teg (Fooser)
PCV valve can affect idle too...
followthadollar
Apr 20, 2010 06:23 PM
immalooser
Feb 18, 2009 05:23 AM
speed junk1e
May 29, 2004 10:49 PM
preluder
Jul 30, 2003 10:23 AM
