Problem with Integra after Timing advance....
Old Aug 30, 2004 | 12:11 AM
Weapon_R's Avatar
Default Problem with Integra after Timing advance....
I advanced the timing to 18 degrees this weekend, and found that the car ran noticably better.
The problem, however, arose the next day when I started the car. Rather than jump to the standard 1500rpm warming up period, it hesitated and choked its way up.
I warmed the car up and went back to the garage, and put the timing back at stock, yet it still does this.
Any idea why? I noticed it was choking when I was removing the last bolt on the distributor.
Old Aug 30, 2004 | 01:07 AM
JFG Kevin's Avatar
Default Re: Problem with Integra after Timing advance.... (MickeyA)
maybe yor distrubutor is still out of place. Or your cam gear are our of place, cut if you came gear slip.
Old Aug 30, 2004 | 01:37 AM
xero-cool's Avatar
Default Re: Problem with Integra after Timing advance.... (aznstyler119)
did you use a timing gun to advance your timing? maybe it's not actually 18 degrees? did u use 91 octane gas?
Old Aug 30, 2004 | 03:11 AM
tekstyle's Avatar
Default Re: Problem with Integra after Timing advance.... (xero-cool)
when i ran advanced timing, i was at 19degrees. the car ran a bit better, but i gotta CEL in a week. i retarded it back to stock and everything was fine after i resetted the light.
Old Aug 30, 2004 | 11:59 AM
Weapon_R's Avatar
Timing is back to stock 16, and it still hesitates to reach the warm up stage. Any other suggestions? I did the timing belt a few weeks ago, and all went well.
Old Aug 30, 2004 | 12:07 PM
1stGENGSR's Avatar
Did you jump the wire on the ECU, so it your (ecu) would learn the new timing? I know that is how my ecu has to be done (92' GSR)......You didn't say what year your teg is, so if it's newer, it might have to be done differently.......
Old Aug 30, 2004 | 12:13 PM
Weapon_R's Avatar
Default Re: Problem with Integra after Timing advance.... (1stGENGSR)
yes, the I jumped it. The car is a 1995
Old Aug 31, 2004 | 12:25 PM
1stGENGSR's Avatar
Something could be up with your Fast Idle Valve, it controls you motor's warm-up.....Take off your intake, and check to see if there is vaccum from the little port inside your throttlebody.......There should only be vaccum from that port during warm-up........
Old Aug 31, 2004 | 01:02 PM
1Quikgsr's Avatar
just leave your timing to stock dont **** with it for what so you can be .2 seconds faster and **** your valves up?
Old Aug 31, 2004 | 01:34 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MickeyA &raquo;</TD></TR><TR><TD CLASS="quote">Timing is back to stock 16, and it still hesitates to reach the warm up stage. Any other suggestions? I did the timing belt a few weeks ago, and all went well.</TD></TR></TABLE>
any codes popping up?
Old Aug 31, 2004 | 01:49 PM
Weapon_R's Avatar
Default Re: Problem with Integra after Timing advance.... (sleeperciv)
Nope no codes whatsoever
Old Aug 31, 2004 | 02:04 PM
2chron4u's Avatar
Default Re: Problem with Integra after Timing advance.... (1Quikgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1Quikgsr &raquo;</TD></TR><TR><TD CLASS="quote">just leave your timing to stock dont **** with it for what so you can be .2 seconds faster and **** your valves up? </TD></TR></TABLE>
whatever man you could advance your timing as far as the distributor wil lturn and you still won't **** anyting up on a stock engine.
advancing the timing to 18 has nothing to do with a bad idle, it's some other component of the car failing and it's just a coincidence
Old Aug 31, 2004 | 02:43 PM
1stGENGSR's Avatar
Default Re: Problem with Integra after Timing advance.... (2chron4u)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2chron4u &raquo;</TD></TR><TR><TD CLASS="quote">
advancing the timing to 18 has nothing to do with a bad idle, it's some other component of the car failing and it's just a coincidence</TD></TR></TABLE>
I have to agree, I have CTRs in my B17A (tight *** clearances) and I run my distributor just shy of all the way advanced because it runs the best at that setting and I have never had any problems due to it.............I've ran it all the way advanced as well and still no problems......
kixcrx
Nov 10, 2006 10:33 AM
*Boostwerks*
Aug 14, 2004 01:42 PM
aron0903
Aug 4, 2004 12:34 AM
Hybridize
Oct 31, 2003 11:31 AM
Ideal R
Jun 28, 2001 09:22 AM
