Problem with Fuel Relay.. please help!
I have a '95 GSR and recently it didn't start. It was getting spark but no fuel. So I took the fuel main relay out and it tested bad. So I got another one, put it in and it fired right up, so I shut it back off. Then later I went to start it again, and nothing. Took that one out and now it tests bad too. Anybody know what else could be causing this.. need the car ASAP!!
All help is appreciated.
I doubt a relay would "go bad" like that. How are you testing it? On the bench, in service, or? Do you hear the fuel pump prime when the ignition is first turned to the "run" position?
Testing it just how it says in the Haynes manual, using a volt tester and before I put the second one in it was fine then when I took it out and tested it again it didn't read anything
Si-Samuri
29
Jun 19, 2008 05:48 PM
