Help me out..
Old Sep 28, 2009 | 02:20 PM
RobEK's Avatar
Icon2 Help me out..
I no this isnt the sections but, I just got done wit my build an i went to go start it an it just cranks over...I changed the main relay an still nothing...i used my boys ecu an still nothing, its getting spark, and all the grounds are good...I took a test like an hooked it up to the positive side of the battery an un-pluged the main relay, an touched the pins....When i did that i heard my fuel pumps turn on an it was building press. Soo i no they work.....i dont know what else it could be...
If anyone has any ideas, please let me know...
Thanks.
Old Sep 28, 2009 | 02:29 PM
underpressure02's Avatar
Default Re: Help me out..
So if I read this correctly you have spark, and you have fuel? Do you have compression? Is your timing off?
Are you sure your fuel pump is priming when you turn the key or only when you jump the main relay?
Old Sep 28, 2009 | 04:25 PM
RobEK's Avatar
the fuel pumps work only when you jump the main relay, an i put a new one in an still nothing...everything else is goood..
Old Sep 28, 2009 | 06:37 PM
RobEK's Avatar
anyone else with some helpfull info??
Old Sep 29, 2009 | 05:38 AM
RobEK's Avatar
someone please help!!!
beatngyou27
10
Nov 4, 2013 08:18 AM
bimmeracer
Jul 16, 2008 06:12 PM
Si-Samuri
29
Jun 19, 2008 05:48 PM
Lb1atx
Aug 1, 2007 10:52 PM
uszcrx
24
Sep 9, 2006 01:05 PM
