Problem With 94 Integra
This is a stock car with 170,000 miles on it..
2 problems with car...
1. when i started the car when it is cold it seems to miss fire rpm back and forth ??? ( the idle screw is all the way in and when it warms up it drops to 600)
2. This just started yesterday. When I stop at a light the idle goes down to like 500 and the car seems like it running on 3 cylinders untill I give it gas and then it is perfect. Car drives great and not all the time does that... I thought maybe injectors or ???? But changed the plugs wires and rotor sooooo??
If anyone know any fix let me know i would apreciate all input thanks
For #1 when you say misfire do you mean it just jumps up and down?
Cuz I have that and it could be a RANGE of small problems on your car. It could be your 02 sensor or anything else. I've read an entire thread regarding this problem on TI.net and everyone had a diff problem/solution.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atg1290 »</TD></TR><TR><TD CLASS="quote">It would be a good thing to do a compression test and come back with soem results...</TD></TR></TABLE>
Don't waste your time - yht problem sounds like the idlve valve.
Kirk@SyndromeAuto
Jan 31, 2007 08:45 PM
